16770 Discussions
Trying to diagnose MCE
HCorb
I am getting repeated lockups/reboots on a laptop. I'm seeing these MCE errors logged:
Hardware event. This is not a software error.
MCE 0
CPU 0 BANK 0
TIME 1444394565 Fri Oct 9 08:42:45 2015
MCG status:
MCi status:
Error overflow
Uncorrected error
Error enabled
Processor context corrupt
MCA: BUS Level-0 Local-CPU-originated-request Generic Memory-access Request-did-not-timeout Error
BQ_DCU_READ_TYPE BQ_ERR_HARD_TYPE BQ_ERR_HARD_TYPE
timeout BINIT (ROB timeout). No micro-instruction retired for some time
failure that caused IERR
STATUS f200084000000800 MCGSTATUS 0
MCGCAP 806 APICID 0 SOCKETID 0
CPUID Vendor Intel Family 6 Model 23
MCE 1
CPU 0 BANK 5
MCG status:
MCi status:
Error overflow
Uncorrected error
Error enabled
MCA: BUS Level-3 Generic Generic Other-transaction Request-did-not-timeout Error
BQ_DCU_READ_TYPE BQ_ERR_AERR2_TYPE BQ_ERR_AERR2_TYPE
received parity error on response transaction
MCE driven
STATUS f200001014000e0f MCGSTATUS 0
MCE 2
CPU 1 BANK 5
MCG status:
MCi status:
Error overflow
Uncorrected error
Error enabled
MCE driven MCE is observed
STATUS f200001030000e0f MCGSTATUS 0
MCGCAP 806 APICID 1 SOCKETID 0
What hardware component is giving this error?
I have tried to update the system BIOS, which has not helped.
I have run memtest, which showed no errors.
Are there any utilities available to help troubleshoot/diagnose this issue?
The machine is a Dell Latitude D830 laptop.
It was running the A15 BIOS, but is showing the same behavior with the A17 BIOS.
I am currently running Ubuntu 14.04.3 LTS
I can boot it to Windows 7 for troubleshooting/diagnostics.
Harland
HCorb
Also, I'm not sure what part of the MCE log is important.
Jose_H_Intel1
You may want to take a look at the following resources:
HCorb
I tried running the processor diagnostic tool, it reports everything is okay.
My laptop is still spontaneously locking up and rebooting.
Jose_H_Intel1
I would contact DELL* support if you have exhausted all other possibilities.
