Turbo boost monitor
Buongiorno,
dopo aver acquistato un notebook che monta un processore I5 450 ho distinstallato e successivamente reinstallato il Turbo boost monitor. Dopo l'installazione non si attiva più la barra blu che entra in funzione in caso di utilizzo intensivo del processore. Non capisco se è dovuto a una errata installazione del gadget o al fatto che il processore utilizza non oltre il 55% della frequenza.
Grazie e buona giornata.
Hello; In order to provide you better assistance on your problem, I recommend to write your problem description in English.
Hello!
At me a similar problem.
I have notebook with processor I5 430. After installation of last driver turbo boost technology has ceased to work boost monitor. Earlier the blue line appeared sometimes even without loading of appendices, now the line has absolutely ceased to rise. With what it can be connected?
DSilv11
Valued Contributor III
Sounds like either the system is idle and has clocked down in speed step mode to save power, or your install is not working?
I believe the monitor also has a averaging setting (but i could be thinking ablut the wrong software) that lets you select how often it updates.
Since the processor can go from Speed Step (~ 1/2 rated speed) to full turbo boost and back hundreds of times a second, a longer averaging period may result in a more steady bar that does not seem to move.
CPUID Tmonitor display turbo boost a little differently http://www.cpuid.com/softwares/tmonitor.html http://www.cpuid.com/softwares/tmonitor.html
Thanks for the answer. Has occurred that the system has passed in a safe battery mode.
