16841 Discussions
Uefi system is corrupted due to failed start with a SSD and Uefi partition not existing on the SSD
ber999
I have investigated the issue further and finally found out that the UEFI Firmware is preventing not only the use of other than HP distributed NVMe SSDs but every NVMe SSD in the slot affected.
The initiating incident was that had replaced the original SSD in the slot by a cloned SSD with larger capacity on which unfortunately the Efi partition was missing and then tried to boot the notebook and got an error message due to the situation.
After that, every attempt to boot the notebook from a SSD in the slot in question failed with the same error message.
Consequently, I have installed the Windows 10 system on the existing HDD in the SATA port, which brought serious performances losses.
Nevertheless, the investigation of the machine revealed that the Uefi hardware initialization which runs at the beginning of the boot process does not assign the NVMe SSD to the correct bus position PCI Express x8 Bus #1 [J6B2], because the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is assigned th this bus position now (see below).
For the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is the PCI Express x16 slot appropriate because of is matching width (x16 and not x8).
As the Uefi hardware-initialization-procedure does not assign the NVMe SSD now, the NVMe SSD hardware cannot be found by any operating system.
The Hwinfo64 report delivers the following results for my HP Pavilion:
  1. in the motherboard section
Motherboard Slots:
2xPCI Express x1, 1xPCI Express x8, 1xPCI Express x16
  1. in the bus section
[General Information]
Device Name:
Original Device Name:
NVIDIA GeForce GTX 1050 Ti (GP107M)
Device Class:
VGA Compatible Adapter
Revision ID:
A1
PCI Address (Bus: Device:
Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1
[PCI Express]
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
8x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
PCI Express Endpoint
Slot Implemented:
No
Emergency Power Reduction:
Not Supported
Active State Power Management (ASPM) Support:
L0s and L1
Active State Power Management (ASPM) Status:
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
2 - 4 us
Maximum Payload Size Supported:
256 bytes
Maximum Payload Size:
256 bytes
Resizable BAR Support:
Not Supported
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
Memory Base Address 0
63000000
Memory Base Address 1
50000000
Memory Base Address 3
60000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Fast Back-to-Back Transactions:
Not Capable
[Driver Information]
Driver Manufacturer:
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.6627 (GeForce 466.27)
Driver Date:
23-Apr-2021
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1\4&33ECA368&0&0008
Location Paths
PCIROOT(0)#PCI(0100)#PCI(0000)
The PCI Express bus enumeration ends with #3 and the NVMe PCIe SSD controller is not listed.
However, a Hwinfo64 report of a comparable board can be found on the Internet.
There, an NVMe PCIe SSD controller is listed in the Bus section (see below) under PCI Express x4.
PCI Express x4 Bus #4
Samsung NVMe PCIe SSD Controller
Device Name:
Samsung Electronics NVMe PCIe SSD Controller
Device Class:
NVMe Controller
Revision ID:
0
PCI Address (Bus: Device: Function) Number:
4:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00
[PCI Express]
Version:
3.0
Maximum Link Width:
4x
Current Link Width:
4x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
8.0 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L1
L1 Entry
L0s Exit Latency:
>4 us
L1 Exit Latency:
32 - 64 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AD200000
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
Standard NVM Express Controller
Driver Description:
Driver Provider:
Microsoft
Driver Version:
10.0.19041.488
Driver Date:
21-Jun-2006
DeviceInstanceId
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00\4&CDF9F35&0&00DC
Location Paths
PCIROOT(0)#PCI(1B04)#PCI(0000)
My HP Pavilion, on the other hand, does not have a PCI Express x4 slot, but it does have a PCI Express x8 slot. According to the Hwinfo64 report of my HP Pavilion notebook, the graphics card NVIDIA GeForce GTX 1050 Ti (GP107M) sits in the PCI Express x8 slot. Specified for this graphics card is x4.
Maximum Link Width:
16x
In the Hwinfo64 report of the board used for comparison, the graphics card is attached to the PCI Express x16 bus #1 (see below) as listed in the Bus section, i.e. in the correct place (16 lanes).
PCI Express x16 Bus #1
NVIDIA GeForce GTX 1060 [GIGABYTE]
Device Name:
NVIDIA GeForce GTX 1060 (GP106M/N17P-G1)
Device Class:
Revision ID:
A1
PCI Address (Bus:Device:Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
16x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L0s and L1
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
8 - 16 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AC000000
80000000
90000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.5167 (GeForce 451.67)
Driver Date:
05-Jul-2020
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1\4&DAED9F9&0&0008
Location Paths
In the System Buses section of the SiSoft Sandra report of my Pavilion notebook (see below), there is a warning 1204 at the end. Possibly, the reference there to the higher maximum supported speed is due to the lower number of lanes (8 in the bus instead of 16).
SiSoftware Sandra Systembusse
Systembusse
Schnittstellenversion: 2.30
PCI Busse: 4
PCIe Busse: 3
Systembus
Typ: PCI
Gerätenummer: 0
Multiplikator: 1x
Systembus
Typ: PCIe 3.0 x8 2.5Gbps
Gerätenummer: 1
Multiplikator: 3x
Bridge: Intel Core6 (Skylake) PCIe Controller (x16)
Systembus
Typ: PCIe 3.0 x1 2.5Gbps
Gerätenummer: 2
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #14
Gerät mit Anschluss verbunden: HP RTL8168/8111 PCI-E Gigabit Ethernet NIC
Systembus
Gerätenummer: 3
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #16
Gerät mit Anschluss verbunden: HP RTS522A PCI Express Card Reader
Leistungstipps
Warning 1204: Speed is below the maximum supported speed. The device may be in power-saving mode.
Tip 3: Press Enter or double-click on a tip to find out more information.
As the NVIDIA graphics card is soldered directly on the motherboard, there is, for test purposes, no possibility to disconnect the NVIDIA graphics card electrically.
I have reported the issue to the Hewlett Packard Enterprise Community community@hpe.com
Mit freundlichen Grüßen
Bernd Dreyer
AndrewG_Intel
Hello @ber999
Reviewing this post, it seems that you are reporting an issue between a discrete Graphics Processing Unit (dGPU) NVIDIA*, NVMe SSDs, and the motherboard/BIOS.
Just to make sure, could you please confirm if you need specific assistance with the Processor? Or are you just posting this as feedback for other users to be aware of? (considering you mentioned you have reported the issue to the Hewlett Packard Enterprise Community).
Andrew G.
ber999
Hello Andrew,
thank you very much. At first, I was on the wrong path, which is depicted in the HP Community thread. I assumed, HP prevents non HP SSD spare parts from operating in HP Notebooks. But, it is wrong in this case.
Later, I found out that a partition copy program, which should copy the updated Windows partition on the SSD clone, had, before copying, deleted all partitions which existed on the clone before, the UEFI Partition included.
In the first thread, I was asked for a missing UEFI Partition on the boot device. Unfortunately, could not remember correctly and answered with no. However, this was wrong.
The first try to boot of the Notebook without an UEFI Partition on the SSD boot device caused that the UEFI firmware does not find an existing SSD in the slot any longer.
The Hardware recognition performed by the UEFI  firmware fails.
I have installed Windows 10 on the HDD of the notebook now. This makes the notebook much slower. Slower as caused by the lower velocity of the HDD only.
Therefore, I have opened a new HP Community Thread.
I am waiting for an answer in this new thread now.
As I guess, HP would not elaborate an UEFI update in this case, I addressed INTEL because of the results of  the TianoCore project or other UEFI software could possibly help.
AndrewG_Intel
Hello ber999
Thank you for your response.
As far as we can see, this issue doesn't seem to be related to Intel® Processor. BIOS is very dependent on the original computer manufacturing (OEM) customizations. We will double-check this internally; however, in order to set the right expectations, we cannot promise anything at this moment since this seems to be an issue specific to HP's BIOS and SSDs.
We will be posting back in the thread as soon as more details are available.
Andrew G.
ber999
Thank you very much.
I have found the post https://www.heise.de/ct/ausgabe/2013-6-UEFI-Funktionen-schuld-an-Notebook-Defekten-2326650.html, which describes the disastrous results from an installation of Ubuntu on UEFI firmware equipped notebooks.
As I have installed Ubuntu after the SSD failed. It could be possible that the problem is related to the Ubuntu installation. Unfortunately I have no computer laboratory to reproduce the events.
n_scott_pearson
An article from June of 2013 doesn't bolster your argument at all.
ber999
After my way of thinking, a similar issue is depicted in this thread PCIe bus interface problem | NVIDIA GeForce Forums.
ber999
The NVIDIA graphics card is assigned to the PCIe x8 slot instead to the PCIe x16 slot.
Moreover, the PCIe x16 slot assignation does not occur in the bus section of the HWInfo 64 report.
Ubuntu is known for overwriting the original graphics card firmware in the hardware.
This could be happend with my HP Pavilion - 17-ab403ng. I don't know how to determine if the firmware was overwritten or not.
Furthermore, I don't know how to install the original HP firmware on the hardware.
Ubuntu is known for overwriting the original graphics card firmware.
AndrewG_Intel
Hello ber999
After checking this further, this does not seem to be related to the processor, so it is better for you to work with the Original Equipment Manufacturer (OEM), especially if this behavior is related to BIOS or system design, which is very dependent on OEM customizations.
Regarding the TianoCore project, you may contact the Intel® Developer Zone to check if more information is available; however, we cannot promise you will receive the assistance you are looking for as the BIOS the PC handles is from HP* and you may need their permission, guidance, advice, etc for any steps that the Developer Zone may suggest (if available).
Our recommendation is that you continue working with HP* Support regarding this behavior.
Andrew G.
