16891 Discussions
Unable to overclock using intel Extreme Tuning Utillity
Tristen_P
here are my relevant specs
CPU: i7 12700kf
GPU: RX 6700xt
RAM: 32GB
MOTHERBOARD: Asus Prime B760 plus D4
750W Evga Power Supply.
When I try to change the voltage for processor core iccmax, or try to enable intel overclocking thermal velocity boost, I get an "unknown error" and my setting does not change. Additionally, there are a lot of bars that are greyed out completely. For example, reference clock, core voltage mode, intel turbo boost tech, core voltage, avx2 ratio offset.
Andres_Intel
Hello Tristen_P,
Thank you for posting on the Intel communities. I am sorry to hear that you are having overclocking issues with your Intel® Core™ i7-12700KF Processor and Intel® Extreme Tuning Utility (Intel® XTU), I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Tristen_P
Hello Andres P.,
Apologies for the slow response time, I've been busy with other responsibilities.  Anyways, I ran the software you instructed me to download. Here is the file linked below.
Andres_Intel
Hello Tristen_P,
Thank you for your response, all the information provided has been really helpful.
I will start with an investigation to provide you with further information as soon as possible.
Andres P.
Andres_Intel
Hello Tristen_P,
We have been working on the investigation, please follow the steps below and let me know the results:
  • Uninstall Intel® XTU by following the How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU) article.
  • Download and install the latest version of Intel® XTU.
  • Make sure you have the latest BIOS version installed. You may want to contact the board manufacturer to ensure this.
  • Admin permission is required for this step: manually delete the c:\program files\Intel\Intel(R) Extreme Tuning Utility directory. Be very careful not to delete any other program folders by default.
  • If the issue persists, update Windows or try a fresh Windows installation.
Andres P.
n1kobg
Set those BIOS Options you want to OC with the software on Auto .  Intel ME have to be installed.
Also, some options can be greyed out because of the way you chose to OC.
Andres_Intel
Hello Tristen_P,
Andres P.
Andres_Intel
Hello Tristen_P,
Andres P.
