Upgrade for PM965
Hello
I have a Notebook from a small Swiss company. It has a PM965 Chipset, CPU-Z says the Model is Crestline+ICH8M.
It features the T2390 CPU, which I want to upgrade.
The manual says that the maximum supported is T7700, but at the time there was no better CPU supported.
Thats why I wanted to ask, which CPU's I can use.
Here are screenshot from CPU-Z:
DArce
Valued Contributor III
Only the motherboard manufacturer or the Original Equipment Manufacturer (on OEM systems) would be able to tell if a given processor will be compatible on a specific system. Specially if the laptop computer was released before the processor came out to the market, most likely the micro-code or the system BIOS will not be able to detect it. You should refer to the manufacturer of your laptop.
