16800 Discussions
Upgraded CPU isn't supporting dual displays anymore
AMill17
Hello
I have a very strange problem. Wishing to increase the speed of my computer cpu-wise I purchased a 2nd hand chip
My system is an old dell Inspiron 580 running windows 7
The chips are
Original on board purchase
INTEL i3 550
INTEL CORE i3
SLBUD COSTA RICA
  1. 3.29GHz/4m/89a
318C344
The new chip is an
INTEL i5 750
INTEL CORE i5
SLBLC MALAY
  1. 2.66GHz/8m/89b
L935B792
Now while the new i5 chip works and I can set the screen resolution to what I want, it doesn't support my dual display! Which I am told by computer savvy friends doesn't make any sense as the CPU has nothing to do with the display output.
The windows setup doesn't detect the DIVD screen with the i5 chip fitted
I have a Nvidia GeForce GTX650 with VGA and DIVD outputs
The monitors are both DELL an ST2420L(DIVD) and an E2210(VGA)
With my original chip, both screens displayed fine and the screens were extended and worked. With the new chip, screen 1 (DIVD) is blank and the desktop is displayed on screen 2 (VGA)
I have tried plugging the VGA screen into the motherboard socket but ended up with no display on either screen.
The research I have done suggest the i5 chip is suitable for my Motherboard so I don't know how to proceed from here, any help would be appreciated
AlHill
Did you check with the motherboard manufacturer to see if their BIOS supports the i5-750?
For an upgrade processor to work, it must be socket, BIOS, and chipset compatible.
Doc
Hello eldarau,
I agree with Doc; did you check with Dell for the compatibility of this processor?
Amy C.
/thread/114664 eldarau, hope you were able to check the compatibility with Dell.
Amy C.
