17279 Discussions
Using OpenCL in GitHub Actions running on windows
SunSerega
GitHub Actions don't have GPUs, but I need a working OpenCL API to run some of the sanity checks of my app.
I know I can run them on Ubuntu and then just:
sudo apt-get install -y ocl-icd-opencl-dev
sudo apt-get install -y pocl-opencl-icd
Then from OpenCL, I see a single OpenCL device, here an example name (from `clGetDeviceInfo` in one of the runs):
> pthread-Intel(R) Xeon(R) CPU E5-2673 v3 @ 2.40GHz
But I need my sanity checks to run on the Windows system due to other limitations (which I'm trying to resolve too, but I can't count on that).
So, from running "Get-WmiObject Win32_Processor" I see:
Caption : Intel64 Family 6 Model 79 Stepping 1
DeviceID : CPU0
Manufacturer : GenuineIntel
MaxClockSpeed : 2295
Name : Intel(R) Xeon(R) CPU E5-2673 v4 @ 2.30GHz
SocketDesignation : None
Model, Stepping, and clock speed change sometimes.
But it's always Intel, 64bit, Family 6, and Xeon.
So, I tried installing drivers from here:
https://www.intel.com/content/www/us/en/search.html#q=Xeon&sort=relevancy&f:@tabfilter=[Downloads]&f:@stm_10385_en=[Graphics]
Here is the main idea:
#Invoke-WebRequest -Uri 'https://downloadmirror.intel.com/30195/a08/win64_15.45.5174.zip' -OutFile 'D:\igfx.zip'
#Invoke-WebRequest -Uri 'https://downloadmirror.intel.com/25308/eng/win64_15407.4279.zip' -OutFile 'D:\igfx.zip'
Invoke-WebRequest -Uri 'https://downloadmirror.intel.com/30382/a08/win64_15.36.5180.zip' -OutFile 'D:\igfx.zip'
7z x "D:\igfx.zip" -o"D:\igfx" -y
Start-Process -FilePath 'D:\igfx\igxpin.exe' -ArgumentList '-overwrite -s -report "D:\igfx.log" -nowinsat' -Wait -Verb RunAs | ForEach-Object { Write-Host $_ }
#Start-Process -FilePath 'D:\igfx\Setup.exe' -ArgumentList '-overwrite -s -report "D:\igfx.log" -nowinsat' -Wait -Verb RunAs | ForEach-Object { Write-Host $_ }
if ([System.IO.File]::Exists("D:\igfx.log")) {
Get-Content "D:\igfx.log"
} else {
Write-Host "No driver install log file found"
In all cases, the installer silently exists without any errors (doesn't even create the .log file), but also doesn't seem to have actually run.
I also tried copying the contents of the "Graphics" folder from these .zip-s to the current directory and `[DllImport]` -ing from some copied .dll-s instead of the system "OpenCL.dll".
- "Intel_OpenCL_ICD64.dll", just like the system "OpenCL.dll", says there are 0 OpenCL platforms.
- "ocl_cpu_IntelOpenCL64.dll" and "IntelOpenCL64.dll" also seem to have the OpenCL API entry points, but trying to get platform count I get `CL_OUT_OF_HOST_MEMORY`.
SunSerega
While locally testing the installer (looking at command line options) - it seems I managed to install it on my system.
Work great, I can now run OpenCL kernel on my CPU but... I have AMD CPU.
For now, only 2 things seem glitchy:
1. If I try to combine GPU and CPU devices in one context - I get AccessViolation, instead of an OpenCL error, if the first device is my NV GPU.
2. In the OpenCL device info I see:
Name = AMD Ryzen 5 2600 Six-Core Processor
Vendor = Intel(R) Corporation
So, should I be worried? Are there any repercussions for just letting the Intel driver run my AMD CPU?
P.S. (and in terms of GitHub Actions - it worked perfectly, no questions there)
Stefan3D
You might get further help in the developer forum: https://community.intel.com/t5/OpenCL-for-CPU/bd-p/opencl
Out of curiosity i tried an AMD CPU with the aforementioned driver and an NVIDIA GPU successfully in Indigo bench
Looks like Intel's driver developer did a good job
