Hi all,
I have implemented a hypervisor with EPT yet, it works well in Windows 7 pro x86, after I run the same hypervisor in Windows 10 pro x86, there is a strange mistake.
First, both the windows 7 machine and the windows 10 1903 machine are 4GB memory, single-core and disable pae and DEP. The machine is running in VMware 16.1 and I use windbg to debug the kernel with pipe. And according to the Microsoft document I have disabled Hyper-V using group policy.
Here is the story.
_ExecuteVmLaunch Proc
vmlaunch
INT 3
ret
_ExecuteVmLaunch Endp
_GuestEntryPoint Proc StdCall _GuestEsp
INT 3
pop ebp
popad
ret
_GuestEntryPoint EndpWhen the vmlaunch execute successfully, the eip will turn to the _GuestEntryPoint, I have tested this in Windows 7 pro x86 machine and it works. When the vmlaunch execute failed, it should turn to the instruction after vmlauch. Both situation will make a INT 3 interrupt.
Now, in the windows 10 machine, strange mistake happened. After the vmlaunch instruction runs, there is not interruption, the windbg only shows "debuggee is running", I can't control the windows 10 machine and there is no BSOD. Even I click break in the windbg, nothing happens. I don't know where is the eip now and what really happens.
I know there must something wrong but I don't know why. Intel document doesn't seem to mention this situation but only the error code. However, the vmlaunch won't ret to let me check the error code.
Thanks you all.
- Tags:
- Hypervisor
Hello 50u1w4y,
I would like to further investigate this for you, therefore, I would appreciate if you could provide the following information for a better understanding of this matter:
- Please provide the model of your processor.
- For how long you’ve been experiencing this behavior?
- Are you a developer? What Intel document did you review? Please provide link.
Esteban D.
Hello Esteban D.
Very thank you for your reply.
Yes, I would provide the information you need.
- From the windows's control panel, my processor is "Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz 2.90 GHz"
- Actually, this is the frist time I experience this behavior because I am just studying VMX and want to realize a specific function.
- Yes, I am a developer. The Intel document I read is "Volume 3 (3A, 3B, 3C & 3D):System Programming Guide ".
Sorry to reply you late. Actually, I doubt that maybe it's because of my code error. Just like the link "VMLAUNCH "hangs" when enabling EPT". However, it works in windows 7 pro x86. So, I doubt that maybe there is something need to change in windows 10 pro x86 but the machine hangs so that I can't debug. I read some code of hypervisor online, all of them related to windows 10 realize in windows 10 x64.
I will follow this topic, thank you for your reply again.
50u1w4y
Hello 50u1w4y,
I hope this post finds you well.
First, thank you for your response and the clarification on this matter.
Based on your inquiry I would strongly recommend that you submit your question on the Intel® Developer Zone.
Please register, and create an account so that you can receive further troubleshooting support, and get access to useful documentation.
I am sure that you will be able to answer all of your concerns with the appropriate support.
That being said, if you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
