16794 Discussions
Vulnerability and Intel-SA-00075
MBrok1
Hello everybody, I hope someone could help me.
I have a PC (assembled with hardware I bought) with a i5-4460 processor, and after running Intel-SA-00075-gui.exe the next information is showed:
Based on the analysis performed by this tool, this system is vulnerable.
Manufacturer: Gigabyte Technology Co., Ltd.
Model: B85M-D3H
Processor Name: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
Windows Version: Microsoft Windows 10 Home
Version: 9.0.30.1482
SKU: Intel(R) Small Business Advantage (SBA)
Provisioning Mode: Not Provisioned
Control Mode: None
Is CCM Disabled: False
Driver installation found: True
EHBC Enabled: False
LMS service state: Running
microLMS service state: NotPresent
I run the following command (although it appears to be disabled):
C:\...>INTEL-SA-00075-console.exe -Unprovision
Unprovision error: Intel(R) AMT is already unconfigured on this system.
The next command stops LMS:
C:\...>INTEL-SA-00075-console.exe -disableLMS
There is a -disableCCM option, but I haven't used it because maybe cannot be reverted.
But I already get the vulnerable system message.
As I don't have an OEM PC, which commands must I use with Intel-SA-00075-console.exe (safely) to solve the problem ?
Thanks !
MikiBroki: Thank you very much for joining the Intel® Processors communities.
Based on the information provided above, you already ran the proper commands and it seems that everything is disable now.
However, you do have an OEM board that belongs to Gigabyte, and the board will still be vulnerable until Gigabyte releases a new BIOS version to fix this problem. So, the best thing to do will be to get in contact directly with them in order to get further details about this subject:
https://www.gigabyte.com/Support
Any further questions, please let me know.
Alberto R
MBrok1
Thanks Alberto, I will contact with Gigabyte support.
So... I don't need to run intel-sa-00075-console.exe with the -disableCCM option (CCM Disabled is False)?
MikiBroki: You are very welcome, perfect.
Correct, you do not need to run that file. Hopefully Gigabyte will be able to provide the proper BIOS version to fix this problem.
Regards.
Alberto R
