- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Mariosopsilos
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Do you have any applications running in the background while you play?
- Do you get any errors with other games/applications?
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
David G
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Why don't you take care of this problem on the game publisher forums?
What do you say you got too many keyboard peripherals connected? Just in case check that you are not using wireless 2.4 g Logitech connection. Problem from PHL. allow.sys. Microsoft still thinks microwaves are a computer virus.
If not using that. It may be your settings and dictionary sync. That thing is also a Microsoft product. Your settings sync so why not decide what to keep. If you're in touch with patience. Read 1, 2, and 3.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
The question sounds moist.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Please share more information about the problem to help you resolve this request, the Intel® SSU doesn't support Windows Vista so you will need to use a newer Windows version. Do you get the same problems with a different Windows version?
David G
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@Mariosopsilos Were you able to check our previous posts?
David G.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We are glad to know you found a solution, since the thread is solved we will close it now.
David G
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
