16928 Discussions
What is the alternative technology for Intel optane memory in generation 12th CPU and z690 MB?
BlueBagheri
Hello. I am Hamid. I use z90 motherboard with intel 12600k processor. I have 3 hard drives  2TB that are Raid0 and have a total of 5.4 TB of space. I wanted to know how to increase the speed of these hard drives that What is the alternative technology of Intel optane memory in intel 12th and chip z 690 gaming? Thanks for Guide...
DeividA_Intel
Hello BlueBagheri,
Thank you for posting on the Intel® communities. I understand you need some information about the Intel® Optane™ Memory Products.
If you want to improve the speed of your storage, you may need to try a solid-state drive (SSD) or an SSD NVMe.
I want to let you know that the Intel® Optane™ Memory products have reached End of Life production and will no longer be supported on newer Intel® Processors starting with the 12th and 13th Generations. Bear in mind that the Intel® Optane™ Memory H10 with Solid State Storage and Intel® Optane™ Memory H20 with Solid State Storage is supported on 12th Generation Intel® Processors with Intel RST driver version 19.0.
I recommend you check with the motherboard manufacturer to confirm if their motherboard is compatible with the Intel® Optane™ Memory technology.
You can find more information related to the Intel® Optane™ Memory in the following links:
1. Intel® Optane™ Memory: https://www.intel.com/content/www/us/en/products/details/memory-storage/optane-memory.html
2. User Guides: https://www.intel.com/content/www/us/en/support/articles/000023989/memory-and-storage/intel-optane-memory.html
3. Intel® Optane™ Memory Products Not Supported on 12th/13th Generation Intel® Processors and Related Platforms: https://www.intel.com/content/www/us/en/support/articles/000057951/memory-and-storage/intel-optane-memory.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
