17046 Discussions
What is the heatsink lbf pressure specification for socket 1151
ssote
New Contributor II
A LGA 1151 i7 67000k does not come with a heatsink so what Pressure does the heatsink need to be?
Hello wingman99,
If you are looking for a CPU cooler for your processor, then any cooler compliant with 1151 socket should work for you.
Making sure you get a manufacturer where they have tested it and follow the installation instructions to avoid any issues.
If more questions are present, feel free to contact us back.
Esteban C
Hello wingman99,
I am here checking if you had any additional inquiries or if the previous question was clarified for you.
Please let me know.
Esteban C
ssote
New Contributor II
Does Intel have any specification on heatsink cooler pressure?
Let me double check if this information is available :)
I will keep you updated.
Esteban C
Hello wingman99,
After deeper investigating, I found no information about the specific pressure done by stock heatsinks.
An option that you can go for would be to check with the manufacturer of our heatsinks (Delta or Foxconn)
Here you can find the support for Delta (check right side of the screen "contact us"): http://bit.ly/2fiFR4g http://bit.ly/2fiFR4g
Then Foxconn:http://www.foxconnsupport.com/Default.aspx%3FLanguage%3Den-us http://www.foxconnsupport.com/Default.aspx?Language=en-us
I did try to check the specs they have available in the website but pressure was not specified.
Hope you can get this information with them
If any additional inquiries come to mind in the future, feel free to let us know.
Esteban C
