17164 Discussions
When starting Intel Application Optimization I get the message Critical Error Could not start
Mfundla
Hi!
1)ASROCK Z790 PG SONIC
2)Intel Core i9 14900K, LGA 1700, OEM [cm8071505094017s rn48]
3)Windows 11PRO 23H2
4)in BIOS Intel_DynamicTuning - Enable ( BIOS last version)
5)installed:
*INF(v10.1.19199.8340)
*Intel_DynamicTuning(v9.0.11401.39039)
*ME(v16.1.25.1917_CONS)
6)When I launch Intel® Application Optimization - I'm getting a message: Critical Error Could not start. PLease contact support
Please help me!
Alberto_R_Intel
Mfundla, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In reference to this scenario and in order to try to fix this problem, please follow the instructions in the link below. Even though it is related to a different error message, it will still help us with this situation:
https://www.intel.com/content/www/us/en/support/articles/000097206.html
Albert R.
Mfundla
The problem was solved after 7 installations of Windows in different versions. As a result, for the ASROCK board, you need to download the drivers from the ASUS board and manually specify the path to the folder with Intel_DynamicTuning through the device manager. And yes, it is important, ALL E-CORE should be enabled in the bios
Alberto_R_Intel
Mfundla, Thank you very much for your response.
Perfect, it is great to hear that the problem with the Intel® Application Optimization was solved and now the tool is working properly.
Thank you also for taking the time to share the solution on this thread, we are sure it will be very helpful and useful for all the peers looking at this conversation.
Any other inquiries, do not hesitate to contact us again.
Albert R.
