16790 Discussions
Why don't half of my Intel CPU tools work?
SPlun1
I have tried everything to open The Diagnostic Tool and The Tuning Utility. They won't install or even open. I have an Intel i7-4970T CPU.
AlHill
What Operating System? Windows 10? What version? 1903 (with all updates)? 1909?
Provided DETAILS.
Doc
SPlun1
Windows 10, ver. 1909
AlHill
And, from where did you download this utility? Provide the link.
Do you have admin privileges on your account?
Doc
SPlun1
The link is https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU. My accounts have administrator privileges.
AlHill
You will notice, in the list of supported processors, that your processor is not supported.
Only X and K processors are supported by XTU.
Doc
SPlun1
Thank you kindly!
SPlun1
My IPDT64 doesn't work either.
AlHill
Make sure you are using the correct download for IPDT:
https://downloadcenter.intel.com/download/19792
Doc
SPlun1
Yes. Didn't help.
AlHill
Are you running 32-bit or 64-bit windows?
Doc
SPlun1
64 bit
AlHill
Then, from the link I provided, you want to install this file: IPDT_Installer_4.1.4.36_64bit.exe
If it fails, provide the error message.
Doc
SPlun1
No error message I just can't get the program to open up it's Processor Diagnostic Features!
AlHill
What version of WIndows 10 are you running? 1909? 1903 (with all updates)?
Doc
SPlun1
1909.
AlHill
Then you have some OS issue. If you are using a 3rd party Antivirus program, disable it or remove it. If you have a 3rd party firewall, remove it. Using Windows Defender and WIndows firewall, does the problem still exist?
Doc
SPlun1
My firewall and antivirus are both Windows. I keep an AVG and WiseCleaner utilities suites running in the background.
AlHill
You have BOTH Windows Defender and AVG running, at the same time? Disable AVG. And, make certain that WiseCleaner is disabled and not running.
You do not want AVG and WiseCleaner to possibly interfere with anything.
Doc
SPlun1
I uninstalled both and can now install IPDT. I can even repair it, but still can't open it!!!!
AlHill
Clearly, your windows configuration with tools like AVG and WiseCLeaner are causing you problems. You need to do a clean install of Windows without adding junk like avg and wisecleaner and any other 3rd party junk.
IPDT installs and runs on Windows 10. Your problem is with your system, which you need to cleanup first.
Doc
