17248 Discussions
XTU 10 : GPU Ram display error
Michon
I run XTU on windows 11 Pro, with the latest Core Ultra 7 265K, and when display the overview of the system, it show the intel graphic RAM (4Gb) instead of my Nvidia 4070 Ti RAM (12Gb) as you can see in the screen below.
Seems DAC Type too is not on the right place...
pressed_for_time
Valued Contributor III
This is a motherboard BIOS issue.
I note that XTU reports the BIOS as 1.A20 which I assume is MSI 7E22v1A2 which is the release BIOS for Z890 motherboards.
There is a newer BIOS - Beta 7E22v1A21 dated October 30 2024 - and this is the MSI information about it
"...Description:
- Updated Intel CPU uCode 0x112
- Fixed the conflict issue between discrete GPU and integrated GPU
- OC solution."
The XTU issue seems to relate to one of the fixes so I would suggest installing this BIOS.
Michon
Following your advice, i flash the BIOS to the newest Beta 1.21, but nothing change...
pressed_for_time
So not the BIOS but it does eliminate the now fixed iGPU, discrete GPU conflict issue.
Can't see anything else obvious, you have the latest iGPU driver from the board manufacturer. And I take it you have installed the Intel chipset driver and Intel Management Engine driver from MSI.
