16891 Discussions
XTU - What happened to the XTUCLI.EXE interface application
TAS3086
The Extreme Tuning Utility command line interface (xtucli.exe) seems to have disappeared in recent versions of the program.
Has it been discontinued.  I used to use it to tune down the processor automatically when the  processor temp got to high and restore when temp went down.  Now I have to use the GUI, and it takes additional time.
Alberto_Sykes
TAS3086, Thank you for posting in the Intel® Communities Support.
In order to provide the most accurate assistance on this matter, we just wanted to confirm a few details about this scenario:
The feature XTUCLI.EXE interface, that was an option inside the Intel® XTU or it was something that you get where you were loading or downloading the application?
By any chance, do you have the option to provide a screenshot of the Intel® XTU that shows where the feature that you are referring to was located?
Albert R.
A Contingent Worker at Intel
TAS3086
was part of the installation package. Its version is 6.4.1.25 dated 9/6/2018
I:\xtu\Intel(R) Extreme Tuning Utility\Client>xtucli /?
************** XtuCLI Command Line Usage *****************
XtuCLI.exe -i/-t/-m/-h <options>
-h / -help : Help information will be available on console and info.txt
-i/ -info: information
<options> can be system, tuning, monitoring, all
Example: XtuCLI.exe -i all
Gives you the information about system, available controls, monitors in the system on console and will be available on system.txt,tuning.txt,monitoring.txt respectively You can use controls and monitor id's for further usage of XtuCLI.exe
-t/ -tune: tune the controls available in the system
Example 1: XtuCLI.exe -t -id 29 -v 33
This will tune the control "1 Avtive Core" control to the value 33. Get the available controls Id details using -i options
Example 2: XtuCLI.exe -t -id 29 -> This will get the control name and active value of control id 29
-m/ -monitor: Gets the Monitor information on console and text file. use -i to get available monitor id's in the system.
Example: XtuCLI.exe -m -id 6
this will get the monitor name "Processor Graphics Frequency" and the current value.
and output will be get written to info.txt
XtuCLI.exe -i/-t/-m xml <options>
Example 1: XtuCLI.exe -i system xml Creates an xml file with name System.xml which contains all the systeminfo details in XTU_xmlFiles in C folder.
Example 1: XtuCLI.exe -i tuning xml Creates an xml file with name Tuning.xml which contains all the tuning information details of controls in XTU_xmlFiles in C folder.
Example 1: XtuCLI.exe -i monitoring xml Creates an xml file with name Monitor.xml which contains all the monitor details in XTU_xmlFiles in C folder.
I hope this helps
TAS3086
interesting, the old xtucli works with the current installed package.  Here is a sample run.
NOTE: any of these options can be immediately changed. This is how I change the processor config when it gets too hot. Item#2701131777 provides the current temperature.
I:\xtu\Intel(R) Extreme Tuning Utility\Client>xtucli -i tuning
48 Turbo Boost Power Max 88W 1.000 4095.875 0.125 7994
47 Turbo Boost Short Power Max 110W 1.000 4095.875 0.125 7994
49 Turbo Boost Short Power Max Enable 1 0 1 1 2
66 Turbo Boost Power Time Window 8Seconds 1 128 1 24
84 Processor Current Limit 105.000A 0.000 1023.875 0.125 8192 110 1 0 1 1 2
80 Overclocking Lock 1 0 1 1 2
50 Package Turbo Power Lock 0 0 1 1 2
41 Enhanced Intelr SpeedStep Technology 1 0 1 1 2
26 Intelr Turbo Boost Technology 1 0 1 1 2
1 Reference Clock 100.000MHz 43.357 540.000 -0.500 3448
88 Core Voltage Mode 0.0 0.0 1.0 1.0 2
2 Core Voltage 1.108V 0 2.000 0.500 1538
34 Core Voltage Offset 0mV -1000 999 1 2048
81 Processor Graphics Voltage 0V 0 2.000 0.500 1538
83 Processor Graphics Voltage Offset 0mV -1000 999 1 2048
78 Cache Voltage Mode 0.0 0.0 1.0 1.0 2
77 Cache Voltage 1.200V 0 2.000 0.500 1538
79 Cache Voltage Offset 0mV -1000 999 1 2048
87 Processor Integrated VR Efficiency Mode 1.0 0.0 1.0 1.0 2
86 Processor Integrated VR Faults 1.0 0.0 1.0 1.0 2
29 1 Active Core 46x 8 80 1 73
30 2 Active Cores 45x 8 80 1 73
31 3 Active Cores 44x 8 80 1 73
32 4 Active Cores 43x 8 80 1 73
3489660933 Processor Core Ratio 43x 8 80 1 73
76 Processor Cache Ratio 46x 8 80 1 73
59 Processor Graphics Ratio Limit 12.5x 0.0 28.5 0.5 58
and
************ Monitoring Information *****************
ID Name Value[Unit]
1000 Package TDP 5.8177434224499443215517991138W
1001 Core TDP 1.1664482909086559678099215157W
1002 Graphics TDP 0.0145176360373794918649292094W
2768240644 Core Voltage 0.717V
15 Reference Clock Frequency 99.94703372252747252747252747MHz
5 Max Core Frequency 3.1991644511735149188843681318GHz
4 Active Core Count 1
3 Thermal Throttling 0
7 Core 0 Temperature 30°C
8 Core 1 Temperature 32°C
9 Core 2 Temperature 29°C
10 Core 3 Temperature 31°C
41 Core 0 Frequency 2.78866378469884GHz
42 Core 1 Frequency 2.33341709961345GHz
43 Core 2 Frequency 2.80504401982698GHz
44 Core 3 Frequency 3.20085982747124GHz
65 Core 0 Voltage 0.720V
66 Core 1 Voltage 0.722V
67 Core 2 Voltage 0.721V
68 Core 3 Voltage 0.723V
90 Core 0 Utilization 7%
91 Core 1 Utilization 5%
92 Core 2 Utilization 10%
93 Core 3 Utilization 6%
2701131777 Package Temperature 33°C
20 Processor Cache Frequency 1.4992055058379120879120879120GHz
22 Power Limit Throttling 0
23 Current Limit Throttling 0
6 Processor Graphics Frequency 599.68220233516483516483516482MHz
2768240652 Graphics Voltage 0V
2768240653 Graphics Temperature 31°C
TAS3086
While the XTUCLI.EXE old program seemed to work, it is capable of viewing all the processor settings, and appears to make changes, BUT the changes are NOT changed in the operation of the system.
So I would still like to know if the if the utility is still available, or do I need to go back and reinstall the old program?
Thank you in advance for a reply.
Terry
Alberto_Sykes
TAS3086, You are very welcome, thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_Sykes
Hello TAS3086, I just received an update on this matter.
After further research we can confirm that the option has been removed from versions after the 6.4.1.25.
So, if you need this implementation, to install an Intel® XTU version older than 6.4.1.25. will be needed.
Albert R.
TAS3086
where can I get 6.4.1.25 or the previous version? Should 6.4.1.25 work?
