16761 Discussions
XTU fails to set turbo-ratio limits
It lets me try to set the turbo multipliers (sandy bridge), but after restarting, I get a message from XTU saying that it could not apply the multipliers.
Everything else I've tried to change works. I have successfully changed BCLK, power limits, memory frequency, memory timings. Many other option such as voltages and GPU clocks are available too, but I haven't touched them.
There are possible issues that may be related to this problem. One is that the CPU is an ES. The CPU doesn't even have a proper name, and reports itself as "CPU 0". Another thing is that I'm currently experiencing a bug where the CPU is misreporting its power draw whenever there is GPU activity. (I will link an additional thread explaining this issue after this.)
screenshot links:
http://i.imgur.com/io25EJu.png CPU info
http://i.imgur.com/T1qHpcC.png XTU manual tuning page
http://i.imgur.com/s91Kr1x.png XTU failing to set multipliers
Laptop is a Clevo P150EM with P170EM bios and a modified ME FW to allow BCLK overclocking. Chipset is HM77.
Thanks for reading.
Please keep in mind that the Intel® Extreme Tuning Utility is designed for certain Intel® motherboards and processors. We can expect different issues and problems during installation if this utility is installed on OEM systems or non-supported products.
