16771 Discussions
Xeon Platinum 8180m wont turbo boost correctly when hyperthreading enabled
Sinon
hey just seeing if anyone can help or has any input on this, i have an Xeon 8180m setup on a asus ws c621e sage motherboard, when i enable hyperthreading the clock speeds will drop down to 3.2ghz max when running benchmark and even if i open something as small as google chrome but as soon as i disable hyperthreading everything works great and it boosts over 3.5ghz all correctly as it should with many programs open, i tried many bios settings with no success, i have attached 2 pictures below, thank you
Hyperthreading OFFHyperthreading OFFHyperthreading ONHyperthreading ON
Sinon
new info to this, bcdedit /set useplatformclock true causes the turbo boosting to stop working again just like when hyperthreading is enabled
