Is it possible to use an Xeon X5450 "S-Spec SLBBE" and an "X5450 "S-Spec SLASB" on an Dual-Processor-Mainboard (at the same time), or is it necessary to use two processors with the same S-Spec type?
Thank you for the information.
We would recommend using the same stepping on the system. To avoid any performance issue or no boot situation it will be required to use the same stepping processors.
