16590 Discussions
appropriate settings for an I7 13700 MHz
rob768
Hi, I am having problems with this new PC i build. It is based on a Gigabyte Z790 Elite AX Mobo, with the mentioned processor, 32 GB 5600 MHz ram (Corsair) and a Zotac 4080 super GPU.  The CPU is cooled by a huge Thermalright peerless assassin 120 SE cooler (running Win11)
The problem is that if I use the default bios settings of the board, my CPU runs hot when playing COD, and runs into crashes.
I lowered voltage setting from 1.2V to 1.185V, and also a magnifier van 34 to 30. By doing this, max temperature fluctuates in the 60-70, which i think is ok. Temperature in the case fluctuates a little but is never hotter than 45 degrees C.
However, as i haven't got a clue about what i am doing, I was wondering if these setting are somehow dangerous, and also if there are better setting i can use to keep my system stable. Because that's all i want, I am not after the highest possible speed (in the game, my GPU takes care of that)
Suggestions and remarks are more than welcome (and also how default settings of a Mobo can cause this, I assumed they were safe settings)
best, rob
rob768
It's a 13700K processor, by the way.
pressed_for_time
Valued Contributor II
Yours settings are OK, CPU temperatures of 60 to 70C under heavy load are fine and perfectly safe. If the system is stable then I would be inclined to leave it as it is.
