hi
i have one lenovo G570G with Intel Mobile Celeron Dual-Core B800
this is the General informations of my prossesor
ypehttp://www.cpu-world.com/CPUs/CPU.html CPU / MicroprocessorMarket segmentMobileFamilyhttp://www.cpu-world.com/CPUs/Celeron_Dual-Core/TYPE-Mobile%20Celeron%20Dual-Core.html Intel Mobile Celeron Dual-CoreModel number http://www.cpu-world.com/Glossary/P/Processor_Model_number.html ? B800CPU part numberFF8062701142600 is an OEM/tray microprocessorFrequency (MHz) http://www.cpu-world.com/Glossary/C/CPU_Frequency.html ? 1500Bus speed (MHz) http://www.cpu-world.com/Glossary/F/Front_Side_Bus_%28FSB%29.html ? 5 GT/s DMIClock multiplier http://www.cpu-world.com/Glossary/B/Bus_clock_multiplier.html ? 15Package988-pin micro-FCPGA10 (rPGA988B)SocketSocket G2 (rPGA988B)Size1.48" x 1.48" / 3.75cm x 3.75cmIntroduction datePrice at introductionS-spec numbersProduction processorsPart numberhttp://www.cpu-world.com/sspec/SR/SR0EW.html SR0EWFF8062701142600+Architecture / MicroarchitectureMicroarchitectureSandy BridgeProcessor core http://www.cpu-world.com/Glossary/C/Core_name.html ? http://www.cpu-world.com/Cores/Sandy%20Bridge.html Sandy BridgeCore stepping http://www.cpu-world.com/Glossary/C/Core_stepping.html ? Q0 (SR0EW)CPUID206A7 (SR0EW)Manufacturing process0.032 micron High-K metal gate processData width64 bitNumber of cores2Floating Point UnitIntegratedLevel 1 cache size http://www.cpu-world.com/Glossary/L/Level_1_cache.html ? 2 x 32 KB instruction caches2 x 32 KB data cachesLevel 2 cache size http://www.cpu-world.com/Glossary/L/Level_2_cache.html ? 2 x 256 KBLevel 3 cache size2 MBPhysical memory (GB)8MultiprocessingNot supportedFeatures
- MMX instruction set
- SSE
- SSE2
- SSE3
- Supplemental SSE3
- SSE4.1 http://www.cpu-world.com/Glossary/S/SSE4.1.html ?
- SSE4.2 http://www.cpu-world.com/Glossary/S/SSE4.2.html ?
- Extended Memory 64 technology (EM64T) http://www.cpu-world.com/Glossary/E/Extended_Memory_64_technology_%28EM64T%29.html ?
- Execute disable bit http://www.cpu-world.com/Glossary/E/EVP_XD.html ?
- Virtualization technology (VT-x) http://www.cpu-world.com/Glossary/V/Virtualization_Technology.html ?
- Dual-channel DDR3 memory controller
- Direct Media Interface
- PCI Express 2.0 interface
- HD graphics controller
i want ti put i3 or i5 prossesor and i find this
intel core i5 2540M PGA 988 G2 CPU 2.3 Ghz 3M SR044 Q16P ES
intel core i3 2330M PGA 988 G2 CPU 2.2 Ghz 3M SR04L
CAN I PUT ON MY PC? or what i can put on it? TKS
Message was edited by: stelios398
- Tags:
- Upgrade PC
You need to contact the laptop manufacturer so they can provide you a list of fully tested and supported processors for your laptop system.
Keep in mind that the processor and laptop compatibility is determined by the laptop manufacturer, not by the processor manufacturer.
