16774 Discussions
code erreur 12 sur eGPU en Thunderbolt 3 sur X99P-SLI
frizouille
disposant d'une carte mère Gigabyte X99P-SLI avec un i7 6800K + une nvidia RTX3080 sur le PCIe-1 je branche un eGPU Aorus gaming box RTX3080 sur le connecteur Thunderbolt de la carte mère mais une erreur 12 sur le périphérique depuis Windows 10.
Comment résoudre cela? par mise à jour pilotes Thunderbolt ou réglage du BIOS?
David_G_Intel
Hello frizouille
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Please share with us the following information:
  • Do you use the latest BIOS?
  • Do you get a problem with other Thunderbolt devices?
  • Was this setup working properly before?
  • Windows built
  • Did you make sure to use the latest drivers/firmware of the eGPU?
  • Did you test the eGPU in another system?
  • Did you check the BIOS settings with the OEM?
David G
Intel Customer Support Technician
David_G_Intel
Hello frizouille
David G
David_G_Intel
Hello frizouille
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regards,
David G.
