17151 Discussions
compatibility between X5450 and E5430
Hi everyone =)
I have one supermicro x7dal-e board with only one X5450 processor.
Is it possible to add a E5430 and work at 2.66GHz?
many thanx in advance
AP16
Valued Contributor III
Generally you can not mix different models of CPU in same system, even if all base specs are even or very close. Most boards will not pass POST.
