16766 Discussions
core 2 duo e7500 utilizing only one core
please help im having an intel core 2 duo e7500 when i go to rating it shows only one core in my cpu even in ms config i cant select more then one core because of this issue my pc shows black screen in every racing game which need atlease 2 cores pls tell me how can i enable second core of my cpu
see the screenshots below to see my problem
Hello vanshaj,
Try checking your BIOS configuration for the cores, you should be able to see the cores and if possible enable/disable them.
Amy C.
i have a option in bios its SW single processing mode it was enabled and i had disabled it but nothing changed there is still one core in use
/thread/115335 vanshaj, you may try updating your BIOS to the latest version available from our end: https://downloadcenter.intel.com/download/18881/BIOS-Update-PRG3110H-86A-?product=50375 Download BIOS Update [PRG3110H.86A]
Amy C.
/thread/115335 vanshaj, If you need further assistance let us know.
Amy C.
