16771 Diskussionen
did the ram adata AX3U1600GB2G9-2G buss 1600 work with cpu 2500k
m2010
Anfänger
2.177Aufrufe
did ram adata AX3U1600GB2G9-2G buss 1600 work with cpu 2500k
m.b. asrock z68 pro 3
ram with volt 1.65
4 Antworten
Adolfo_S_Intel2
Mitarbeiter
1.336Aufrufe
This processor supports up to 1333 MHz FSB, so if you install RAM running at 1600 MHz, this RAM will be running at 1333 MHz. in this case I would recommend contacting the motherboard manufacturer for a list of tested RAM for this system.
m2010
Anfänger
1.336Aufrufe
my board is asrock z68 pro 3 and buss in the list of memory but i asked if there any dangrouse with the volt 1.65 on my system hardware that the quition?
Adolfo_S_Intel2
Mitarbeiter
1.336Aufrufe
You should not have any issue, however we do recommend using 1.5 Volts RAM if possible.
m2010
Anfänger
1.336Aufrufe
the ram will work,
what could hapen if i work with ram with volt 1.65 constantly
Antworten
