e8400 p5b overclock
syıld2
hi all>
>I changed my cpu e7200 to e8400 because of no vt support
>so I must update bios also>first try is last bios year 2014 but it crashed and dont enter to hdd
>it stops bios screen and keyboard don t work
>then I changed v2001(year 2008) it crashes again but when I unpluged power and wait a second and pluged it again. it start to work I dont understand.
>sometimes the mainboard starts to work and there is a non stop beepp sound.>
>ohh I forgot to say when it achieve to pass to hdd, the ovberclock failed appers in the screen>
>what must I do? any changes in bios?>
>thanks
AlHill
You must be at Bios 2001 to use the E8400: https://www.asus.com/us/Motherboards/P5B/HelpDesk_CPU/ P5B | Motherboards | ASUS USA
I suggest you use the E7200 to update the bios, then install the E8400.
If you have bios 2001 installed, then either the E8400 processor is bad, or you have a problem with the board or bios settings and should contact ASUS for support.
Doc
Thank you, Al Hill for your contribution.
csselo, I would recommend following Al's advice.
Please don't hesitate in contacting us back if you need further assistance.
JC
Hello csselo,
I was reviewing this thread and I wanted to know if you were able to contact Asus?
JC
