16784 토론
explorer.exe - The memory could not be read. On shutdown/reboot . Faulty 13900k?
SLitw
초급자
1,749 조회수
I plugged this pc and formatted disk in uefi.
13900K stock
2x16 GB DDR5 GSKILL 6800
Rtx 4090 Gigabyte Gaming
Aorus Elite Z790 AX
SSD KINGSTON 2TB
Seasonic 1300W PX ATX 3.0 PCIE 5.
Today i rebooted pc by shutdown button in start menu and this popped:
explorer.exe - application error
The instruction at 0x00007FFD4938C34B referenced memory at
0x0000000000000008. The memory could not be read.
Is my pc stable? I dont oc pc,all stock.No games crashing. No bsods. No errors in karhu ram test.
Someone said this to me in microsoft forum:
"There is a high possibility that this involves your current memory. It can also be older system drivers, faulty CPUs, defective memory, corrupted files, or hardware conflicts. Following my suggestion above can help and I also suggest getting your PC hardware checked by a technician if this error happens again."
Can i have faulty cpu?
0 포인트
2 응답
LeonWaksman
수퍼 사용자
1,737 조회수
Probably this error happened while you tried to shutdown your PC while some process was running (for example downloading some update).  It doesn't indicate a hardware problem.
Leon
0 포인트
SLitw
초급자
1,735 조회수
Yes it happened once. Also closing all background programs and no pop up.
0 포인트
응답
