New Biuld
CPU I5 4570
MAINBOARD ASUS Z87-C
PSU BEQUIET 7 400W
WD RAPTOR
4X2GB RAM VENGEANCE
COOLER INTEL STOCK and try more.
First start up temp is 42° in bios after 5 minutes;
After inizialing install Windows 7 shut down pc
Power and bios show "OVER TEMP" f1 to setup.
Bios show 90°...
check the heatsink and everything is ok
Rate heatsink with another model, same problem
Now turn on the system, the temperature is at 75 ° and increases in Windows
another problem is that the system if I install the video driver intel after the windows logo screen remains black
Now what is the problem?
ps:
it is not my first computer so I know how to mount a heatsink
thanx all
Hello oivilis,
Assuming the heatsink is properly installed (remember it should not wiggle or shake if you attempt to move it; the pins should not come up if you try to pull them up) and the system is running with default settings in BIOS, I may suggest verifying the memory runs at 1600MHz 1.5v. You may also cross you're your processor in a different motherboard or viceversa.
Regarding the black screen issue it is possible you may need the monitor driver so Intel® HD Graphics will load the correct EDID. You may also update the BIOS or use a different HD Graphics driver version (from the disc or from the web).
I hope the suggestions help.
Hello oivilis,
Thanks you for posting your solution to this particular situation.
I am glad to hear you narrowed down the possibilities until you found out it was the processor who was failing.
I hope this helps other with the same issue.
Caesar B_Intel.
