16762 Discussions
how can i fix the ITBM driver not available exiting application?
trick
ive tried everything on the other threads about this issues i still cant get it to work right i dont know if im doing it wrong with installing it or what ive updated everything that i think of the BOIS,drivers and whatever esle i can think of and it si still saying the samething when i restart my computer is there any toher workarounds or fixs? thanks for everyone time and answers
Hello ssjarheadss,
Thank you for contacting the Intel community.
Would you please provide us with your system information to better assist you?
You can use the Intel SSU (System Support Utility) to get your system information (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility):
Download Intel® System Support Utility
  1. Download the utility
  2. Run the exe and select 'Scan'
  3. Save and include as an attachment in the Intel Community Forum
Ivan.
trick
here you go hope this what you need
Hello ssjarheadss,
Unfortunately, the Intel(R) Core(TM) i7-6700K processor does not support Intel® Turbo Boost Technology 3.0; you can check the Intel® processors supported here:
http://www.intel.com/content/www/us/en/support/processors/000021587.html http://www.intel.com/content/www/us/en/support/processors/000021587.html
You can also check the list of processor supported by the Intel® Turbo Boost Technology 3.0 at:
https://downloadcenter.intel.com/download/26103/Intel-Turbo-Boost-Max-Technology-3-0 https://downloadcenter.intel.com/download/26103/Intel-Turbo-Boost-Max-Technology-3-0
Ivan.
trick
thank you @Ivan. for the response and info that answered all my questions i was asking thank you again Ivan
You are more than welcome!
Best wishes,
Ivan.
