16773 토론
i have latency spikes with my i7 6700 ingame. game freeze for a half a sec .the latency is from cpu.
νανασ
초급자
6,300 조회수
i have latency spikes with my i7 6700 ingame. game freeze for a half a sec .the latency is from cpu. i have the following system( i have change allready the psu, ram, ssd ,hdd, mobo . graphics card.)
i7 6700
ram crucial ddr4 16gb
asus H170M-PLUS
asus strix gtx 1060 6gb
ssd crucial 275gb
hdd western digital blue 2tb
its very annoying i cant play properly any game old or new. how can i receive support in greece?
0 포인트
16 응답
직원
3,576 조회수
Hello razorblade334:
Since you replaced all the parts and the problem remains, basically that indicates the issue seems to be related to the processor itself.
Did it work fine before?
Now, for testing purposes you can always try to use the PC and play the game without the graphics card, this is just to check if the problem persists, remember that when you use a video card the graphics of the processor get disable, and everything will depend on the video card, so it will help to let us know if there might be a compatibility problem with the video card itself. If you have the chance of trying this process, here is the link for the graphics driver of the processor:
https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530 https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530
Did you install the latest graphics drivers for the video card?
Have you tried a BIOS update on the board?
Did you test it with just one memory stick at the time?
By any chance do you have the model or a part number for the memory RAM so we can check the specifications of it?
In you are interested in replacing the processor, remember it has 3 years of warranty, please use the following link to get in contact with your local support area:
http://www.intel.eu/content/www/eu/en/support/contact-support/emea-contact.html http://www.intel.eu/content/www/eu/en/support/contact-support/emea-contact.html
Any further questions, please let me know.
Alberto
0 포인트
νανασ
초급자
3,576 조회수
My problem persists with Intel integrated graphics too.I have latency in the same spots.I will check the parts of ram tomorrow. It's a crucial 2133 mhz but I don't know exactly the model.
0 포인트
직원
3,576 조회수
We are sorry to hear the problem remains with the Intel® graphics as well.
Perfect, no problem, take your time and once you get the chance please let us know the model of the RAM just to make sure it is fully compatible and that is running at stock configuration:
DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V
http://ark.intel.com/products/88196/Intel-Core-i7-6700-Processor-8M-Cache-up-to-4_00-GHz http://ark.intel.com/products/88196/Intel-Core-i7-6700-Processor-8M-Cache-up-to-4_00-GHz
Additionally, please provide the information requested on the following link, that is in order for us to try to replicate the issue:
/thread/77761 https://communities.intel.com/thread/77761
Did you try driver 4614:
https://downloadcenter.intel.com/download/26604/Graphics-Intel-Graphics-Driver-Beta-15-45-?product=88345
Alberto
0 포인트
직원
3,576 조회수
I just wanted to check if you were able to get the model of the RAM and install driver 4614, also if you saw the information we are requesting on the previous post?
Alberto
0 포인트
νανασ
초급자
3,576 조회수
ι fount my ram model. its crucial 2x8 ddr4 2133mhz CT8G4DFS8213.C8FBR (SERIAL NUMBER IS 136EC6CC) .
as the driver all my drivers are updated.
0 포인트
직원
3,576 조회수
Thank you very much for letting us know all that information.
The memory RAM seems to be fully compatible, and if the PC is showing latency with both, the Intel graphics and the Nvidia graphics, then the problem as you mentioned seems to be related to a different component.
Were you able to do the BIOS update?
Did you test the PC using just one memory stick at the time?
Do you have the option to test it with a different memory kit?
Do you have the option to test your processor on a different board or your board with a different processor? By trying this step, we will be able to identify if problem is related to the board or to the processor.
Which Windows version are you using?
On the following link, you will find a tool that does an overall test on the processor, it is a very reliable tool, so if the processor passed the test, it means it should be working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Alberto
0 포인트
νανασ
초급자
3,576 조회수
Thanks for the help and for the response.I using the latest updated version of the win 10 64bit home. I have updated the bios to the latest available.in don't have the option to try the Cpu on another board or the board to other system.it's my only desktop pc.I will try to use only one stick of ram each time and I will tell you if something changed. Thanks a lot and sorry for my English. .
0 포인트
직원
3,576 조회수
You are welcome.
Thank you very much for letting us know those details, I understand perfectly.
No problem at all, take your time to do the tests and as soon as you get the chance, please let us know the results.
Alberto
0 포인트
직원
3,576 조회수
I just wanted to check if you were able to do the tests and if you need further assistance with this matter?
Alberto
0 포인트
νανασ
초급자
3,576 조회수
hello again. latency and stuttering in games are still and i found something important. i downloades the intel proccesor diagnostic tool and i was run the tests and when PCH test beggins FAILED! here is the foto. i have warrandy can you replaced my proccesor?intel_admin...what is that error?
0 포인트
직원
3,576 조회수
Hi, razorblade334, Thank you very much for letting us know that information and for the picture.
In regard to your inquiry, the PCH is the Platform Controller Hub and basically what is does is work as a BUS to allow the communication between the processor and the motherboard, so if the processor failed that part of the test, there might be something wrong with it or with the board.
About the warranty on the processor, yes, of course we can replace it for you if it is still under warranty, in order to do that please get in contact directly with Intel so they can provide all the details about the replacement process:
Chat support; http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat,
For phone support in Europe, you will see the contact information on the link below:
EMEA contact information: http://intel.ly/28QeAF3 http://intel.ly/28QeAF3
Alberto
0 포인트
νανασ
초급자
3,576 조회수
Hello Alberto.I don't know which number must I call because I live in Greece and it doesn't in list.do you know where I is support centre here? As for PCH fail message I updated from main board factor the asus sata drivers and now the test is succeed. But the latency and stuttering is still persists in all games.
0 포인트
직원
3,576 조회수
Hi, razorblade334, Thank you very much for sharing those results, we are glad to hear that the processor passed the test. Just to let you know, the issue could be related to the video card as well, so if you have the option to test the PC with a different video card or without the video card that will be a good option to confirm that possibility.
This is the number you need to use to contact Intel:
01793 404925 Monday – Friday 08:30- 16:00 (UK Time)
Alberto
0 포인트
νανασ
초급자
3,576 조회수
I have allready changed the video card with a different new one and a psu as well but the problem persists and as I see from monitoring tools the latency comes from the Cpu. My previous card was a gigabyte gtx 1060 and I change it will an Asus gtx 1060 strix.and nothing changed.
0 포인트
직원
3,576 조회수
razorblade334, Thank you very much for providing those details. In that case, yes, you can go ahead and replace the processor because based on the information you gave us, the problem could be related to it.
Please use the phone number provided on the previous post or contact Intel directly through chat in order to replace the processor.
Alberto
0 포인트
νανασ
초급자
3,576 조회수
My ram is crucial 2x8 ddr4 2133 mhz. I don't know exactly which model.I was tried the driver but I have latencies with Intel card disabled and gtx 1060 in use.something goes bad with Cpu or the chipset.
0 포인트
응답
