16864 Discussions
i5-10400f compatibility with Windows 11
InfamousDJ
Hello! I see the Intel Core i5-10400F CPU on Microsoft's list of processors that are compatible with Windows 11, but the PC Health Check app says my device isn't compatible because no TPM is detected. I've checked in BIOS, and the appropriate setting is Enabled, but BIOS also says there is no TPM detected.
Is there anything I can do to make my device compatible with Windows 11?
AlHill
Update your bios.
Make sure TPM (Ptt) is turned ON in the bios.
RUN TPM.MSC and report back with what it says.
[W10 is this generation's XP]
