16968 Discussions
i5-13400 running below ambient
galactica_phantom
Hi, i tried Intel Costumer Support with no luck. They said it's normal, but my CPU can't run below ambient temperature, it's a fact. I owned a 12400 and i made a little upgrade. I sold my previous CPU and bought this one (13400). The 12400 ran perfectly, no issues at all. Cores and package were above ambient temperature. But this one isn't. I ran Intel XTU, Intel Diagnostic Tool, Intel ID Utility, everything seems fine. In fact, load temps are also very low. Maybe a broken sensor? I need a solution.
Here are some pics of the issue:
n_scott_pearson
Just throwing in my two cents worth.
It's most-definitely NOT a broken sensor. You have separate DTS sensors in every core and they are all consistent in their representation of temperatures. Further, the package temperature readings are determined from the various DTS readings and remain consistent with them.
I am suspicious that an offset has been written to the Temperature Target MSR, causing all readings to be skued low (this would be a mobo BIOS issue). Can you dump the contents of this MSR?
galactica_phantom
Hello, and thanks for your answer. How can i do that (dump the contents of this MSR)? Sorry for my ignorance. Cheers.
galactica_phantom
Which tool and/or command should i use? Could you provide me a link and the command that i should use? Thanks.
galactica_phantom
Hi, again. Sorry to bother you. I can't do what you ask. Could you please give me a hand? My board is an ASUS B660-A ROG Strix WiFi with the latest BIOS.
galactica_phantom
I tried Crystal CPU ID. I don't know if this it the dump you wanted. Sorry.
MSR : 63-32 31-0
00000000 : 00000000 00001FFF
00000001 : 00000000 00000000
00000006 : 00000000 00000040
00000010 : 000002E6 77760E8F
00000017 : 00040000 00000000
0000001B : 00000000 FEE00C00
00000020 : 0350EEC1 F9866521
00000021 : 0DE1F549 FC0756BE
00000022 : 8E2A605E 2B89849D
00000023 : 79BD6994 C6A790C1
0000002A : 00000000 00000000
0000002E : 00000000 00000000
00000033 : 00000000 00000000
00000034 : 00000000 00000151
00000035 : 00000000 000A0010
0000003A : 00000000 00000005
0000003B : FFFFFFFF FFFFFFF1
00000048 : 00000000 00000001
0000004E : 00000000 00000001
0000007A : 00000000 00000000
00000080 : 00000000 00000000
0000008B : 00000026 00000000
0000009B : 00000000 00000000
000000A0 : 00000000 00000000
000000A5 : 00000000 00000000
000000A7 : 00000000 00000000
000000AF : 00000000 00000002
000000BC : 00000000 00000000
000000C1 : 00000000 00000000
000000C2 : 00000000 00000000
000000C3 : 00000000 00000000
000000C4 : 00000000 00000000
000000C5 : 00000000 00000000
000000C6 : 00000000 00000000
000000C7 : 00000000 00000000
000000C8 : 00000000 00000000
000000CD : 00000000 00000000
000000CE : 00040838 F0811900
000000CF : 00000000 000000FD
000000E1 : 00000000 00000000
000000E2 : 00000000 74008008
000000E4 : 00000000 00051814
000000E7 : 00000028 45A064C4
000000E8 : 0000001C 38A6CF06
000000FE : 00000000 00005D0A
00000102 : 00000000 00000000
00000103 : 00000000 00000000
00000104 : 00000000 00000000
0000010A : 00000000 0088FD6B
00000110 : 00000000 00000001
00000118 : 00000000 00000000
0000011F : 00000000 00000000
0000013A : 00000010 00000000
0000013C : 00000000 00000001
00000140 : 00000000 00000000
00000150 : 00000005 00000000
00000151 : 00000000 00000003
00000174 : 00000000 00000000
00000175 : 00000000 00000000
00000176 : 00000000 00000000
00000179 : 00000000 00000C14
0000017A : 00000000 00000000
0000017F : 00000000 00000000
00000186 : 00000000 00000000
00000187 : 00000000 00000000
00000188 : 00000000 00000000
00000189 : 00000000 00000000
0000018A : 00000000 00000000
0000018B : 00000000 00000000
0000018C : 00000000 00000000
0000018D : 00000000 00000000
00000194 : 00000000 00010000
00000195 : 00000000 00000002
00000198 : 0000213C 00002900
00000199 : 00000000 00002F00
0000019A : 00000000 00000000
0000019B : 00000000 00000010
0000019C : 00000000 884F0000
0000019D : 00000000 00000000
000001A0 : 00000000 00850089
000001A1 : 00000000 00003AC5
000001A2 : 00000000 0A641400
000001A4 : 00000000 00000000
000001A6 : 00000000 00000000
000001A7 : 00000000 00000000
000001A8 : 00000000 00000000
000001AA : 00000000 000030C2
000001AD : 29292929 2D2D2E2E
000001AE : 08070605 04030201
000001B0 : 00000000 00000006
000001B1 : 00000000 884A0000
000001B2 : 00000000 02000000
000001C6 : 00000000 00000003
000001D9 : 00000000 00000000
000001DD : 00000000 00000000
000001DE : 00000000 00000000
000001E0 : 00000000 00000000
000001F0 : 00000000 00000074
000001F1 : 00000000 00000000
000001F2 : 00000000 7B000006
000001F3 : 00000000 FF000C00
000001F5 : 0000007F FFE00C00
000001FB : 00000000 0000000E
000001FC : 00000000 00FC0059
00000200 : 00000000 80000000
00000201 : 0000007F 80000800
00000202 : 00000000 7C000000
00000203 : 0000007F FC000800
00000204 : 00000020 00000000
00000205 : 00000060 00000800
00000206 : 00000010 00000000
00000207 : 00000070 00000800
00000208 : 00000040 00000000
00000209 : 00000040 00000800
0000020A : 00000000 00000000
0000020B : 00000000 00000000
0000020C : 00000000 00000000
0000020D : 00000000 00000000
0000020E : 00000000 00000000
0000020F : 00000000 00000000
00000210 : 00000000 00000000
00000211 : 00000000 00000000
00000212 : 00000000 00000000
00000213 : 00000000 00000000
00000250 : 06060606 06060606
00000258 : 06060606 06060606
00000259 : 00000000 00000000
00000268 : 05050505 05050505
00000269 : 05050505 05050505
0000026A : 05050505 05050505
0000026B : 05050505 05050505
0000026C : 05050505 05050505
0000026D : 05050505 05050505
0000026E : 05050505 05050505
0000026F : 05050505 05050505
00000276 : 00000030 00000000
00000277 : 00070106 00070106
00000280 : 00000000 40000001
00000281 : 00000000 40000001
00000282 : 00000000 40000001
00000283 : 00000000 40000001
00000284 : 00000000 40000001
00000285 : 00000000 40000001
00000286 : 00000000 40000001
00000287 : 00000000 00000000
00000288 : 00000000 40000001
00000289 : 00000000 40000001
0000028A : 00000000 40000001
0000028B : 00000000 40000001
0000028C : 00000000 40000001
0000028D : 00000000 40000001
0000028E : 00000000 40000001
0000028F : 00000000 40000001
00000290 : 00000000 40000001
00000291 : 00000000 40000001
00000292 : 00000000 40000001
00000293 : 00000000 00000000
000002A0 : 00000000 7A60000E
000002D9 : 00000000 00000000
000002E0 : 00000000 00000000
000002E7 : 00000000 00000001
000002FF : 00000000 00000C06
00000302 : 0000FFFF FFFF0001
00000304 : 00000000 585DE000
00000305 : 00000000 00000000
00000309 : 00000000 00000000
0000030A : 00000000 038F1ADA
0000030B : 00000000 022E8E5A
0000030C : 00000000 00000000
00000329 : 00000000 00000000
00000345 : 00000000 000074FF
0000038D : 00000000 00000330
0000038E : 00000000 00000000
0000038F : 00000000 000000FF
00000390 : 00000000 00000000
00000391 : 00000000 00000000
00000392 : 00000006 00000000
00000396 : 00000000 00010008
000003F1 : 00000000 00000000
000003F2 : 00000000 00000000
000003F6 : 00000000 0000FFFF
000003F7 : 00000000 00000800
000003F8 : 00000000 00000000
000003F9 : 00000000 00000000
000003FA : 00000000 00000000
000003FC : 00000000 00000000
000003FD : 00000000 20CBBEBC
000003FE : 000001B9 7CD8B652
00000400 : 00000000 00001FFF
00000401 : 00000000 00000000
00000402 : 00000000 00000000
00000403 : 00000000 00000000
00000404 : 00000000 0000001F
00000405 : 00000000 00000000
00000406 : 00000000 00000000
00000407 : 00000000 00000000
00000408 : 00000000 0000001F
00000409 : 00000000 00000000
0000040A : 00000000 00000000
0000040B : 00000000 00000000
0000040C : 00000000 0000007F
0000040D : 00000000 00000000
0000040E : 00000000 00000000
0000040F : 00000000 00000000
00000410 : 00000000 00000000
00000411 : 00000000 00000000
00000412 : 00000000 00000000
00000413 : 00000000 00000000
00000414 : 00000000 00000000
00000415 : 00000000 00000000
00000416 : 00000000 00000000
00000417 : 00000000 00000000
00000418 : 00000000 000000FF
00000419 : 00000000 00000000
0000041A : 00000000 00000000
0000041B : 00000000 00000000
0000041C : 00000000 0000003F
0000041D : 00000000 00000000
0000041E : 00000000 00000000
0000041F : 00000000 00000000
00000420 : 00000000 00000000
00000421 : 00000000 00000000
00000422 : 00000000 00000000
00000423 : 00000000 00000000
00000424 : 00000000 000007FF
00000425 : 00000000 00000000
00000426 : 00000000 FEF00400
00000427 : 00000038 80000086
00000428 : 00000000 000007FF
00000429 : 00000000 00000000
0000042A : 00000000 FEF00440
0000042B : 00000038 80000086
0000042C : 00000000 000007FF
0000042D : 00000000 00000000
0000042E : 00000000 FEF00600
0000042F : 00000038 80000086
00000430 : 00000000 000007FF
00000431 : 00000000 00000000
00000432 : 00000000 FEF00640
00000433 : 00000038 80000086
00000434 : 00000000 000007FF
00000435 : 00000000 00000000
00000436 : 00000000 FEF00040
00000437 : 00000038 80000086
00000438 : 00000000 000007FF
00000439 : 00000000 00000000
0000043A : 00000000 FEF00000
0000043B : 00000038 80000086
0000043C : 00000000 000007FF
0000043D : 00000000 00000000
0000043E : 00000000 FEF00240
0000043F : 00000038 80000086
00000440 : 00000000 000007FF
00000441 : 00000000 00000000
00000442 : 00000000 FEF00200
00000443 : 00000038 80000086
00000444 : 00000000 000007FF
00000445 : 00000000 00000000
00000446 : 00000000 00000000
00000447 : 00000000 00000000
00000448 : 00000000 000007FF
00000449 : 00000000 00000000
0000044A : 00000000 00000000
0000044B : 00000000 00000000
0000044C : 00000000 00000000
0000044D : 00000000 00000000
0000044E : FFFFFFFF FFFFFFFF
0000044F : FFFFFFFF FFFFFFFF
00000480 : 03DA0500 00000013
00000481 : 000000FF 00000016
00000482 : FFFBFFFE 0401E172
00000483 : F77FFFFF 00036DFF
00000484 : 0076FFFF 000011FF
00000485 : 00000000 7004C1E7
00000486 : 00000000 80000021
00000487 : 00000000 FFFFFFFF
00000488 : 00000000 00002000
00000489 : 00000000 01FF2FFF
0000048A : 00000000 0000002E
0000048B : 075D7FFF 00000000
0000048C : 00000F01 06F34141
0000048D : 000000FF 00000016
0000048E : FFFBFFFE 04006172
0000048F : F77FFFFF 00036DFB
00000490 : 0076FFFF 000011FB
00000491 : 00000000 00000001
00000492 : 00000000 00000001
00000493 : 00000000 00000000
000004C1 : 00000000 00000000
000004C2 : 00000000 00000000
000004C3 : 00000000 00000000
000004C4 : 00000000 00000000
000004C5 : 00000000 00000000
000004C6 : 00000000 00000000
000004C7 : 00000000 00000000
000004C8 : 00000000 00000000
000004E0 : 00000000 00000005
000004E2 : 00000000 0000000A
000004E3 : 00000000 00000000
000004E8 : 00000000 00000000
000004EA : 00000000 00000FFF
00000503 : 00000000 00000000
00000540 : 00000000 00000001
00000541 : 00000000 00000000
00000560 : 00000000 00000000
00000561 : 00000000 0000007F
00000570 : 00000000 00000000
00000571 : 00000000 00000000
00000572 : 00000000 00000000
00000580 : 00000000 00000000
00000581 : 00000000 00000000
00000582 : 00000000 00000000
00000583 : 00000000 00000000
00000600 : FFFFD780 601BC6E0
00000601 : 00000000 00000000
00000603 : 00360000 00363636
00000606 : 00000000 000A0E03
00000607 : 00000000 00000000
00000608 : 00000000 00000003
00000609 : 00000000 00000000
0000060A : 00000000 00000000
0000060B : 00000000 00000000
0000060C : 00000000 00000000
0000060D : 00000087 00A19537
00000610 : 004284D0 00A18208
00000611 : 00000000 0D554FA7
00000613 : 00000000 00000000
00000614 : 00000000 00000208
00000615 : 00000000 00000000
00000618 : 00000000 00000000
00000619 : 00000000 00000000
0000061B : 00000000 00000000
0000061D : 00000080 933CB80B
00000620 : 00000000 0000082A
00000621 : 00000000 00000029
00000622 : 00000000 00000001
00000623 : 00000000 00000001
00000630 : 00000000 00000000
00000631 : 00000000 00000000
00000632 : 00000000 00000000
00000633 : 00000000 00000000
00000634 : 00000000 00000000
00000635 : 00000000 00000000
00000636 : 00000000 00000000
00000638 : 00000000 00000000
00000639 : 00000000 0417AF34
0000063A : 00000000 00000010
00000640 : 00000000 00000000
00000641 : 00000000 00000000
00000642 : 00000000 00000010
00000648 : 00000000 00000019
00000649 : 00000000 00000000
0000064A : 00000000 00000000
0000064B : 00000000 80000000
0000064C : 00000000 00000000
0000064D : 00000000 00000000
0000064E : 00000000 789DFDA2
0000064F : 00000000 10001000
00000650 : 21212121 21212121
00000651 : FFFFFFFF FFFFFFFF
00000658 : 00000286 92CEB335
00000659 : 0000014B C072A82D
0000065A : 00000000 00000000
0000065B : 00000000 00000000
0000065C : 00000000 00DD0000
0000065E : 00000000 00000000
0000065F : 00000000 00000001
00000660 : 000000E5 85791461
00000664 : 00000000 00000000
00000680 : 00000000 00000001
000006A0 : 00000000 00000000
000006A2 : 00000000 00000000
000006A4 : 00000000 00000000
000006A5 : 00000000 00000000
000006A6 : 00000000 00000000
000006A7 : 00000000 00000000
000006A8 : 00000000 00000000
000006B0 : 00000000 00000000
000006B1 : 00000000 01000000
000006E0 : 00000000 00000000
000006E1 : 00000000 00000000
00000770 : 00000000 00000001
00000771 : 00000000 0110203B
00000772 : 00000000 8000FF01
00000773 : 00000000 00000005
00000774 : 0000019E 54003B02
00000775 : 00000000 00000000
00000776 : 00000000 00000000
00000777 : 00000000 00000004
00000802 : 00000000 00000029
00000803 : 00000000 01060015
00000808 : 00000000 00000000
0000080A : 00000000 00000000
0000080D : 00000000 00020200
0000080F : 00000000 000001DF
00000810 : 00000000 00000000
00000811 : 00000000 00000000
00000812 : 00000000 00000000
00000813 : 00000000 00000000
00000814 : 00000000 00000000
00000815 : 00000000 00000000
00000816 : 00000000 00000000
00000817 : 00000000 00000000
00000818 : 00000000 00000000
00000819 : 00000000 00000000
0000081A : 00000000 00000000
0000081B : 00000000 00000000
0000081C : 00000000 00000000
0000081D : 00000000 00000000
0000081E : 00000000 00000000
0000081F : 00000000 00000000
00000820 : 00000000 00000000
00000821 : 00000000 00000000
00000822 : 00000000 00000000
00000823 : 00000000 00000000
00000824 : 00000000 00000000
00000825 : 00000000 00000000
00000826 : 00000000 00000000
00000827 : 00000000 00000000
00000828 : 00000000 00000040
0000082F : 00000000 00000035
00000830 : 00000001 0000082F
00000832 : 00000000 000000D1
00000833 : 00000000 000000CD
00000834 : 00000000 000000FE
00000835 : 00000000 000100D8
00000836 : 00000000 00000400
00000837 : 00000000 000000E2
00000838 : 00000000 0000012C
00000839 : 00000000 0000011B
0000083E : 00000000 0000000A
00000990 : 00000000 00000000
00000991 : 00000000 00000004
00000C80 : 00000000 40000000
00000C82 : 00000000 00000000
00000C85 : 00000000 00000000
00000C87 : 00000000 00000017
00000C8F : 00000000 00000000
00000C90 : 00000000 00000FFF
00000C91 : 00000000 00000212
00000C92 : 00000000 00000EAA
00000C93 : 00000000 00000EEE
00000C94 : 00000000 00000FFF
00000C95 : 00000000 00000FFF
00000C96 : 00000000 00000FFF
00000C97 : 00000000 00000FFF
00000C98 : 00000000 00000FFF
00000C99 : 00000000 00000FFF
00000C9A : 00000000 00000FFF
00000C9B : 00000000 00000FFF
00000C9C : 00000000 00000FFF
00000C9D : 00000000 00000FFF
00000C9E : 00000000 00000FFF
00000C9F : 00000000 00000FFF
00000D10 : 00000000 000003FF
00000D11 : 00000000 000003FF
00000D12 : 00000000 000003FF
00000D13 : 00000000 000003FF
00000D14 : 00000000 000003FF
00000D15 : 00000000 000003FF
00000D16 : 00000000 000003FF
00000D17 : 00000000 000003FF
00000DA0 : 00000000 00000900
00000E1F : 0000000F 02040107
00000E20 : 00000000 00000000
00000E21 : 00000000 00000000
00000E22 : 00000000 00000000
00000E23 : 00000000 00000000
00000E24 : 00000000 00000000
00000E25 : 00000000 00000000
00000E26 : 00000000 00000000
00000E27 : 00000000 00000000
00000E28 : 00000000 00000000
00000E29 : 00000000 00000000
00000E2A : 00000000 00000000
00000E2B : 00000000 00000000
00000E2C : 00000000 00000000
00000E2D : 00000000 00000000
00000E2E : 00000000 00000000
00000E2F : 00000000 00000000
00001200 : 00000000 00000000
00001201 : 00000000 00000000
00001202 : 00000000 00000000
00001203 : 00000000 00000000
00001204 : 00000000 00000000
00001205 : 00000000 00000000
00001206 : 00000000 00000000
00001207 : 00000000 00000000
00001208 : 00000000 00000000
00001209 : 00000000 00000000
0000120A : 00000000 00000000
0000120B : 00000000 00000000
0000120C : 00000000 00000000
0000120D : 00000000 00000000
0000120E : 00000000 00000000
0000120F : 00000000 00000000
00001210 : 00000000 00000000
00001211 : 00000000 00000000
00001212 : 00000000 00000000
00001213 : 00000000 00000000
00001214 : 00000000 00000000
00001215 : 00000000 00000000
00001216 : 00000000 00000000
00001217 : 00000000 00000000
00001218 : 00000000 00000000
00001219 : 00000000 00000000
0000121A : 00000000 00000000
0000121B : 00000000 00000000
0000121C : 00000000 00000000
0000121D : 00000000 00000000
0000121E : 00000000 00000000
0000121F : 00000000 00000000
000014CE : 00000000 00000000
000014CF : 00000000 00000020
00001500 : 00000000 00000000
00001501 : 00000000 00000000
00001502 : 00000000 00000000
00001503 : 00000000 00000000
00001504 : 00000000 00000000
00001505 : 00000000 00000000
00001506 : 00000000 00000000
00001507 : 00000000 00000000
00001508 : 00000000 00000000
00001509 : 00000000 00000000
0000150A : 00000000 00000000
0000150B : 00000000 00000000
0000150C : 00000000 00000000
0000150D : 00000000 00000000
0000150E : 00000000 00000000
0000150F : 00000000 00000000
00001510 : 00000000 00000000
00001511 : 00000000 00000000
00001512 : 00000000 00000000
00001513 : 00000000 00000000
00001514 : 00000000 00000000
00001515 : 00000000 00000000
00001516 : 00000000 00000000
00001517 : 00000000 00000000
00001518 : 00000000 00000000
00001519 : 00000000 00000000
0000151A : 00000000 00000000
0000151B : 00000000 00000000
0000151C : 00000000 00000000
0000151D : 00000000 00000000
0000151E : 00000000 00000000
0000151F : 00000000 00000000
00001600 : 00000000 00000000
00001601 : 00000000 00000000
00001602 : 00000000 00000000
00001603 : 00000000 00000000
00001604 : 00000000 00000000
00001605 : 00000000 00000000
00001606 : 00000000 00000000
00001607 : 00000000 00000000
00001608 : 00000000 00000000
00001609 : 00000000 00000000
0000160A : 00000000 00000000
0000160B : 00000000 00000000
0000160C : 00000000 00000000
0000160D : 00000000 00000000
0000160E : 00000000 00000000
0000160F : 00000000 00000000
00001610 : 00000000 00000000
00001611 : 00000000 00000000
00001612 : 00000000 00000000
00001613 : 00000000 00000000
00001614 : 00000000 00000000
00001615 : 00000000 00000000
00001616 : 00000000 00000000
00001617 : 00000000 00000000
00001618 : 00000000 00000000
00001619 : 00000000 00000000
0000161A : 00000000 00000000
0000161B : 00000000 00000000
0000161C : 00000000 00000000
0000161D : 00000000 00000000
0000161E : 00000000 00000000
0000161F : 00000000 00000000
000017D0 : 00000008 7F7FC001
000017D1 : 00000000 00000003
000017D2 : 80000000 00000000
000017D4 : 00000000 00000001
000017DA : 00000000 00000001
00001830 : 00000000 00FFFFFF
00001831 : 00000000 00AAAAAA
00001832 : 00000000 00101011
00001833 : 00000000 00001001
00001834 : 00000000 00000000
00001835 : 00000000 00000000
00001836 : 00000000 00000000
00001837 : 00000000 00000000
00001838 : 00000000 00000000
00001839 : 00000000 00000000
0000183A : 00000000 00000000
0000183B : 00000000 00000000
0000183C : 00000000 00000000
0000183D : 00000000 00000000
0000183E : 00000000 00000000
0000183F : 00000000 00000000
00001850 : 00000000 00FFFFFF
00001851 : 00000000 00555555
00001852 : 00000000 00404044
00001853 : 00000000 00004004
00001854 : 00000000 00000000
00001855 : 00000000 00000000
00001856 : 00000000 00000000
00001857 : 00000000 00000000
00001858 : 00000000 00000000
00001859 : 00000000 00000000
0000185A : 00000000 00000000
0000185B : 00000000 00000000
0000185C : 00000000 00000000
0000185D : 00000000 00000000
0000185E : 00000000 00000000
0000185F : 00000000 00000000
00001890 : 00000000 00FFFFFF
00001891 : 00000000 00212121
00001892 : 00000000 00AEAEAA
00001893 : 00000000 00FFAFEA
00001894 : 00000000 00FFFFFF
00001895 : 00000000 00FFFFFF
00001896 : 00000000 00FFFFFF
00001897 : 00000000 00FFFFFF
00001898 : 00000000 00FFFFFF
00001899 : 00000000 00FFFFFF
0000189A : 00000000 00FFFFFF
0000189B : 00000000 00FFFFFF
0000189C : 00000000 00FFFFFF
0000189D : 00000000 00FFFFFF
0000189E : 00000000 00FFFFFF
0000189F : 00000000 00FFFFFF
000018B0 : 00000000 000003FF
000018B1 : 00000000 00000155
000018B2 : 00000000 00000021
000018B3 : 00000000 00000001
000018B4 : 00000000 00000000
000018B5 : 00000000 00000000
000018B6 : 00000000 00000000
000018B7 : 00000000 00000000
000018B8 : 00000000 00000000
000018B9 : 00000000 00000000
000018BA : 00000000 00000000
000018BB : 00000000 00000000
000018BC : 00000000 00000000
000018BD : 00000000 00000000
000018BE : 00000000 00000000
000018BF : 00000000 00000000
000018D0 : 00000000 000003FF
000018D1 : 00000000 000002AA
000018D2 : 00000000 00000012
000018D3 : 00000000 00000002
000018D4 : 00000000 00000000
000018D5 : 00000000 00000000
000018D6 : 00000000 00000000
000018D7 : 00000000 00000000
000018D8 : 00000000 00000000
000018D9 : 00000000 00000000
000018DA : 00000000 00000000
000018DB : 00000000 00000000
000018DC : 00000000 00000000
000018DD : 00000000 00000000
000018DE : 00000000 00000000
000018DF : 00000000 00000000
00001A8F : 00000000 40070007
00001A90 : 00000000 000000FF
00001A91 : 00000000 000000FF
00001A92 : 00000000 000000FF
00001A93 : 00000000 000000FF
00001A94 : 00000000 000000FF
00001A95 : 00000000 000000FF
00001A96 : 00000000 000000FF
00001A97 : 00000000 000000FF
00001B01 : 00000000 00000000
n_scott_pearson
MSR 1A2 is the Temperature Target MSR Your's has value is 00000000 0A641400. This indicates that Tjmax is 100c (0x64) but that an offset of 10 is being applied (meaning that throttling isn't going to happen until 110c (0x64+0x0A)). I will presume that the motherboard's BIOS is responsible for this (non-zero) offset - unless perhaps you are running XTU? I believe it also means that 0x0A will be added to all readings.
Ok, oddly enough, I interpret this as meaning that all readings from the DTS will be 10c higher than otherwise. Logic (a.k.a wishful thinking) would say that I must somehow be reading this backwards (i.e., readings will be 10c lower than expected) but I don't think so.
So, outcome, question: Why is this offset being applied and who is applying it?
galactica_phantom
Oh, i did it right then? Lol. I'm surprised. Hi! How are you? I don't know who is applying it. I had a 12400 and the temperatures were ok. With this CPU i'm having this offset temperature that you mention. What to do? I tried every option in BIOS, in fact i tried all settings to default. Maybe the CPU is applying the offset? I don't think so. Please let me know if there is something i can do. Thanks!!
EDIT: I'm not using Intel XTU.
EDIT 2: An option appeared in BIOS with this CPU. I can set the TJ Max to 90°C to avoid issues and i can put a +10°C offset in CoreTemp to see the correct temps too. What do you think?
n_scott_pearson
I wouldn't do that. What I would do is reset the BIOS to its default configuration and see if that removes the application of this offset.
galactica_phantom
Hi, i did it with no luck. What could it be? Should i try another board or CPU?
Here are my specs:
i5-13400
4x8GB Corsair Vengeance Pro RGB 3200MHz
Zotac 3060 Ti Twin Edge OC
Kingston Renegade 500GB
WD Blue SN550 1TB
Samsung EVO 860 1TB
Seasonic Focus GX-850
Corsair 275r Airflow
H115i RGB Pro XT
3x ID Cooling RGB 120mm
n_scott_pearson
Have you verified that this processor is actually supported by this board with this BIOS version? Have you verified that you are using the latest BIOS that they've made available?
galactica_phantom
Yes, all 13th gen CPUs are supported by this board since BIOS Rev 1620. I am also using the latest BIOS.
I don't know if this help, but i was using a 12400 with 0 issues.
EDIT: In fact, i only found ONE person with this exact same issue. A guy with a 12700K.
Here's the link: https://community.intel.com/t5/Processors/Faulty-12700k-thermal-sensor-temperatures-too-low/m-p/1385794
EDIT 2: I tried to downgrade my BIOS but it says that any BIOS released before the last one isn't a proper BIOS file. It's protected and i can't downgrade it.
Tomorrow, or next monday, i'll try to reach ASUS and told them that i have this issue. Don't know what to do at this point.
Maybe, they added a +10°C TJMax to this board with a BIOS update. I don't know.
n_scott_pearson
It is interesting that it is the processor upgrade process that results in this issue. This says to me that there is some artifact of the original processor being left in the BIOS. This is something that the motherboard vendor needs to resolve. Contact their support people for next-steps.
galactica_phantom
Even after updating to the latest BIOS with the 13400?
EDIT: I reached ASUS support. I think they put people to attend tech support that know less than i do. Hopeless.
EDIT 2: I downgraded to BIOS version 2015 (2022/10/19). No luck either.
n_scott_pearson
Yes. Updating (or downgrading) the BIOS doesn't necessarily eliminate any of the data stored in the flash. In fact, even resetting the BIOS configuration doesn't necessarily eliminate any of this data.
I am at a loss what to suggest next. Have those ASUS support people escalate the issue to their next level support.
galactica_phantom
Is this an issue to be concerned about? You told me an 10°C offset had been applied, but it isn't the real temp. My concern is the following: will i have any issues such as condensation or some other problem? The CPU has been working fine for a month. Thanks for all your help.
galactica_phantom
It was the CPU. I tried another 13400 (but the F variant and a RPL one) and temps are fine now. Thanks for all your help and time. I really appreciate it!
