i5 2500k die map
Hi, new to the forum and hoping someone may be able to help. I have an Asus Sabretooth P67 mobo with 2 damaged pins. Have been able to identify the pins in the socket as:- Pin No. Pin Name. Buffer Type CPU No.
K-13 VSS GND AA33
M-20 VSS GND V35
The Cpu No. is the contact with the socket. My question is, does anyone know what the Cpu No.`s are and what effect if any, they will have in the performance of mobo and cpu. Have looked through Intel documents as supplied by Asustek and Adolfo. Managed to work out the pin numbers and the contact points on the cpu from the socket and cpu die map. But can find no reference to what the Cpu No`s represent. Looking at the die map, i think they may have something to do with graphics. If so, is it cpu or gpu? Thanks in advance.
Salem_W_Intel1
For your specific inquiry, I'd recommend referring to a field application engineer. For this, please, contact an Intel Authorized Distributor. A list of these can be found at the following web site:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
