16761 Discussions
i5-4460 windows 10 32bit drivers, when? there is one for 64bit. can't upgrade to windows 10.
AApos2
Get Windows 10 application points to to intel for lacking on drivers, which impedes my upgrade to windows 10. The frustration and dissapointment for intel not being ready for such a big event is real and big. At least is there an ETA? There is already one driver but for windows 10 64bit.
Ronny_G_Intel
AlexApo,
I would recommend that you check the following website for further information about Windows* 10 running on Intel products:
http://www.intel.com/support/processors/sb/CS-035705.htm?wapkw=windows+10 http://www.intel.com/support/processors/sb/CS-035705.htm?wapkw=windows+10
If your processor is an http://ark.intel.com/products/80817/Intel-Core-i5-4460-Processor-6M-Cache-up-to-3_40-GHz Intel® Core™ i5-4460 Processor (6M Cache, up to 3.40 GHz) it is validated to run with Windows* 10 64bit only, see here: http://ark.intel.com/products/codename/42174/Haswell# @All http://ark.intel.com/products/codename/42174/Haswell# @All
Intel has currently no plans to support Windows* 10 32-bit from a Driver Support standpoint.
AApos2
Thank you for taking the time to answer me, although the answer is not what I was hoping/wanting to be. Having communicated with microsoft, I know that I have to upgrade first to windows 10 32bit version, since I own the windows 7 32bit version, in order to activate the windows 10. Then I can clean-install the 64bit version. By the answer you gave me I understand that because of my poor choice of using an Intel's product I can now do neither, impeding me from taking advantage of a limited-time free upgrade to an all-new OS. This outcome really saddens me and it will be taken into consideration for future purchases.
Again, thank you for taking the time to answer me.
