17147 Discussions
i5 CPU M480 - message log: Please check your Processor Thermal Solution
My notebook began to turn itself off when the cpu usage reached 80% ~ 90%.
Idid the tests with IPDT tool and failure times, turning off the notebook.
WILL THERMAL PASTE?
LOG IPDT:
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 18/04/2016 04:10:23
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Mon Apr 18 04:10:23 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Mon Apr 18 04:10:23 2016
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 47 degrees below max
CPU Brand String Test
Start Time: Mon Apr 18 04:10:24 2016
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
End Time: Mon Apr 18 04:10:24 2016
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
Expected CPU Frequency: 2.67
Detected CPU Frequency: 2.80365
Expected Base Clock: 133.33
Detected Base Clock: 133.507
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Mon Apr 18 04:10:25 2016
Total Time: seconds: 1
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Mon Apr 18 04:10:25 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 374.4
Error: 0
--- Floating Point Test Passed!!!---
End Time: Mon Apr 18 04:10:27 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Mon Apr 18 04:10:27 2016
Test Result - PASS
Operation Per Second: 1.32916e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Mon Apr 18 04:10:29 2016
Cache Test
Start Time: Mon Apr 18 04:10:29 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 3072
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> No
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> No ---> No Test Required
PCLMULQDQ - Polys Carry-Less Multiply Supported --> No ---> No Test Required
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
No AVX AES PCLMULQDQ Tests required
If you are able to add or replace more thermal paste, that would help.
Please try some steps available at: http://www.intel.com/content/www/us/en/support/processors/000005776.html http://www.intel.com/content/www/us/en/support/processors/000005776.html
Since this is a laptop computer, please check with your computer manufacturer for possible warranty options
Allan
Allan
Hi Allan, I will change the thermal paste, the current is hard and dry...
My laptop is already outside the manufacturer's warranty... I got it to 5 years.
Last time I changed the thermal paste was in late 2014.
thanks
