- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I am also facing this problem. I just bought a Rog Strix G615JHR on 5th August 2025 with an i7 14650hx and an rtx 5050, it idles at about 55 to 60 degree Celsius and whenever i open valorant or even any other games like gta v or mw3 or battlefield 6 the temp goes up to 95 sometimes even 97 but this happens only when i put the laptop in turbo mode but the gpu temp always stay around 60 to 75 degrees even with ultra settings in the above mentioned games. Asus said this temperature is fine they did not find any heating issue with the laptop and closed the service request. Asus said this laptop has a liquid metal thermal compound and the fans run at 5800rpm max. Is this an issue with the processor?
Below are the temps during Battlefield 6 and during idle respectively
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Shuichi,
Thank you for posting in our Community. Seeing CPU temps in the mid to high 90s can be worrying, especially on a new system. It’s worth noting that the Intel® Core™ i7-14650HX is designed to operate safely at temperatures up to 100°C under heavy workloads. That said, we’d still like to review your case more closely to make sure the system is behaving as expected and not throttling unnecessarily. To help us better assess the situation, could you please confirm the following details?
- Which BIOS version and Intel® drivers (especially chipset and ME firmware) are currently installed?
- At idle (55–60°C), are there any applications running in the background (antivirus scans, updates, etc.)?
- Have you tested the same games in “Performance” or “Balanced” mode instead of “Turbo”? If so, what temps do you see?
- When the CPU reaches 95–97°C, does it maintain performance, or do you notice throttling (FPS drops, reduced CPU frequency)?
Your observation that the GPU remains in the 60–75°C range is a good sign, it suggests the cooling system is working as intended for the GPU. We just want to ensure the CPU is also within spec under load.
Have a nice day!
Von M.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hey,
Thanks for reaching out! My current BIOS version is: American Megatrends International, LLC. G615JHR.306, 6/10/2025
And my igpu has the driver version: 32.0.101.6554
At idle nothing runs maybe Nvidia container, windows defender, microsoft office click to run nothing else as such and the temperature is 55-56 degree C at silent mode with power connected. same goes for performance and turbo mode. Now when I launch a game be it GTA V or Valorant, the temperature shots up immeidately to 75 to 80 and then in game it is stuck at 95 sometimes 97 and HwInfo says max temp 100 and Core thermal throttling: Yes I'll attach a screenshot down below. This all happens in performance and turbo modes. and no I don't see a lack of performance. The performance is the same it does not degrade it maintains performance even at 95 to 97 degrees. Now in silent mode the performance does go down a tiny bit in valorant like from 550fps to 410 or 450fps, but the fan does not spin to its full capacity and the cpu temp also goes to 85 to 87. it doesn't touch 90 in silent mode. The GPU remains the same yes.
One more thing when the mode changes from igpu to dgpu, in windows settings it shows that i have two displays 1 and 2, however 2 is my main display and I cant access display 1. My friend told me its the mux switch it does that and after a few restarts it becomes normal. Idk what is this here's a screenshot as well. This laptop is way too costly for me and I'm worried that I might have gotten a defective product and Asus is saying the laptop is not overheating but if I want then they can change the liquid metal thermal compound in this laptop. I intend to play a fair amount of AAA titles and run some LLMs as well I hope I can solve this heating issue. I don't want my laptops cpu to get scorched.
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Shuichi,
Thank you for the detailed information. The temperatures you’re seeing (95–97°C under load, 55–60°C idle) are within the normal operating range for the Intel® Core™ i7-14650HX. This CPU is designed to run safely up to 100°C, and since you’re not experiencing performance loss, your system is working as intended. For lower temps, you can use Performance or Silent mode instead of Turbo, ensure good airflow, or use a cooling pad. A repaste isn’t necessary unless the system throttles heavily. Additionally, the bottom line is that your processor is not defective. Intel® Turbo Boost Technology temporarily increases processor frequency to handle peak workloads, but does not maintain those turbo frequencies continuously. Processor usage and temperatures vary depending on the applications running. When usage is high, it is normal for processor temperatures to rise. All Intel® processors include built-in thermal protection. If the temperature exceeds safe limits, the processor will automatically reduce performance (throttle) or, if necessary, shut down to prevent damage. The temperatures you’re seeing fall within Intel’s operating specifications, and ASUS’s assessment is correct. While 95°C looks high, it is safe for this processor under load. You can continue gaming and running demanding applications without concern. You may also visit this article for more information to know whether your laptop is overheating.
For details on the expected operating temperature range and to report any unusual behavior, please contact your system manufacturer.
Please don’t hesitate to let me know if you need any further assistance.
Von M.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hey Von,
Thanks for helping me! Well I'm not sure if it will work or not but I have been using a cooling pad for the last 3 years. It has 6 fans at 600rpm max i guess and moreover, the temperature reaches 100 in MINECRAFT!! Like how and yes my last max temperature was 102 while running GTA v at max settings without ray tracing. At silent mode now I see the temperature go down but the performance goes down as well, I can see stutters here and there even in Minecraft it stutters in silent mode. In the next mode (aka: PERFORMANCE MODE) the temperature goes from 85 to 95 and 97 in vanilla Minecraft. When I use shaders like BSL or Derivative shaders, the temperature showed 102 max, core thermal throttling: yes and yes the fps drops to 45 sometimes from 120. I play Minecraft for more than 5 or 7 hours and constant temperature of 102 or even 95 or 97 for 7 hours is not good for the processor I guess. In performance mode the fans still do not spin to max speed, I have to go to manual mode and then maximize the fan speed to 5800rpm. Still I have booked a service window again lets see what it can do.
Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Shuichi,
Thank you for sharing these details. I’ll need to conduct additional research on this issue, and I’ll provide an update in this thread once I have more information.
Von M.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Shuichi,
Thank you for your patience. While temperature spikes during gaming can be expected, it is not normal for the processor to consistently reach its maximum operating temperature of 100°C during extended use. The Intel® Core™ i7-14650HX processor can technically operate at these levels; however, sustained gaming temperatures in the range of 95–102°C indicate a thermal management issue that should be addressed.
For additional reference, you may review these Intel® support articles:
Since BIOS updates and system settings adjustments did not resolve the issue, we recommend reaching out to ASUS support once more to request warranty service and ensure proper thermal management for your system.
In the meantime, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
So i solved my issue by calling asus and I told them i need to change the thermal compound and liquid metal and when a guy came and changed it then the issue was solved. In valorant 1600p max graphics the temp of cpu was 87 or 90 sometimes and thats normal for 14th gen. So do give asus a call they'll insist that they'll change the fan but tell them you want to change the compund.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I understand your concern and i also thought that was unnecessary but when he opened it the picture was grim the liquid metal was 40 percent not on the cpu itself and he told me that the gpu paste was completely dry so it was the right thing to do. Maybe your laptop is fine but temp going 95 is a sign of that
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
when did you bought this laptop and did the service was covered under asus warranty? and did you change thermal compound from liquid metal to thermal paste?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am seriously very angry with Asus about this, with a laptop of such a steep price tag and they didn't even offer to replace it only fix it. All I did was mail them and officially complain to them but that was of no use. I would recommend you to not undervolt the cpu and run a few games. After the reapplication of paste there was a boost of FPS on F1 24 and Battlefield 6. So do test that and if HW monitor says that your cpu is going to 100 or 105 then contact asus as you might also have the same issue.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
yes im gonna change the thermal compounds this week i have complained and they said if the problem persists, he told me to service it for free in the service center nearby available.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Can you tell me your GPU temp while playing valorant in turbo or even in performance mode?
Or tell me the gpu temp in any other game.
I think my GPU is now overheating cuz it is reaching 86 to 87 degrees.
I absolutely despise this laptop.
My HP was so much better than this absolute piece of a whack job
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Update:
As of 16th April 2026, my laptop has been constantly turning off due to overheating. On valorant the GPU temperature reached 83 to 85 degree Celcius on 1080p valorant max settings and CPU went 99. On other games like CS2, Peak, one or two steam games and even games like Roblox, the laptop just randomly turned off. No warning no nothing just everything goes black and all my progress lost. I have been told by Asus that this is a safety feature of the Laptop so that the components dont get damaged, however this constant turning off and me trying to turn the laptop on after it turns on is just absurd. So they kept repasting my thermal compounds which made the laptop better for 2 months or so and then back to that same issue of turning off. Asus mainly did these few things:
1. Fan change
2. Thermal paste change (this has been done 3 times)
3. Installation of new OS (Windows 11) twice
Now after much back and forth, I finally gave the service centre my unit and they changed the paste again and tested for a week or two and now, Asus has finally given me a DOA certificate and now I am contacting my merchant about this certificate so I can get a refund of this product.
I would say that Asus has helped me through this even though a replacement or refund is not in their policy but they have given me assurance that if flipkart(the merchant from where I bought this laptop) doesn't help me, they will help me in some way and have kept my ticket open until I get a new unit or a refund. Thats pretty good quality service.
However I would say, maybe my unit was actually a lemon unit, maybe one of the first of this model cuz I didn't find any bad things happening to others having this unit yet because Asus do make quality components, but still if you plan on buying this specific model, Do check other reviews if you can find any!!
My laptop model is the Asus Strix G16 2025 (G615JHR).
Main specs: i716750HX and an RTX 5050 8gb
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
