when I'm gaming (like Warzone), the CPU go up to 98c and stay between 82-96c, it is only me who see a problem with this high CPU temperature... when I check comments on internet people talk about max 80c
- i7 14700k
- Gigabyte z790 Aorus Elite X wifi 7
- CORSAIR Vengeance RGB 32 Go (4x16 Go) DDR5 6000MHz CL36 UDIMM
- GPU Gigabyte GeForce 4070 windforce OC V2 12gb
- heatsink be quiet! Dark Rock Elite (using Artic MX-6 paste)
- SAMSUNG 990 Pro 2TB
- PSU be quiet Power Zone 2 1000w ATX 12v 3.1 plus platinum
- case Antec C8
- Fan: 2x 160mm / 6x 140m
==> modifications made to try to reduce heat (see attachement)
Hi ImNice4u,
- When did the issue start? Was it working fine before?
- What are the troubleshooting steps that you tried so far?
- Have you tired updating the BIOS and apply Intel Default Settings?
- Did you overclock the processor?
- Did you check if there is an excessive build-up of dust in the system
- Have you verified if the processor's fan is still functioning properly
- Have there been any recent changes around the system that might have contributed to the overheating issue
Archie D.
Hello, sorry, I just saw the message. The computer is new, the bios is at its most recent version and nothing is overclocked (the RAM had been set to 6000 but I put it back to default). All the fans work and are even pushed to their maximum speed at all times.
Hi ImNice4u,
Archie D.
Hi ImNice4u,
Thank you for the update. I've sent an email to your active email address for the next step of the process. Please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
Archie D.
Your i7-14700K reaching 82–98°C while gaming is higher than typical, even with a good cooler and airflow. For more information here on optimizing CPU temperatures and fan curves, you can follow Intel’s recommendations. Make sure thermal paste application and case ventilation are also properly set up.
