17048 Discussions
i7-2600k nightmare - thermal safeguard fail.
I had what should have been a gorgeous PC put together sunday night...
Key players:
Intel i7-2600k processor
ASUS Maximus IV Extreme
Cooler Master Silent Gold power supply
Noctua NH-C14 Heatsink
Arctic Cooling MX-4 Thermal Compound
System is turned on... no POST beeps. After about 5 seconds the computer shuts off and then suddenly starts up. Fans are running perfectly, optical drives seem fine. I turned it off, double check the wiring, everything is installed correctly, try again removing some RAM and the video card. Same result. Then I see and smell smoke coming from the socket with a terrible whine and the system shuts down. I'm horrified to discover the pins on the processor have been completely warped and burned, taking out my motherboard socket as well.
I brought all my parts to the service shop at my retailer the next morning, they found the power supply to be fine (which I assumed) and shared in my shock that the processor would burn-out as it did and told me I would have to RMA the damaged products. ASUS customer service was wonderful, took the board back and I should be expecting a replacement in not too long. However when I contacted Intel, the first customer service rep dismissed me immediately saying that Intel would not take back anything damaged. No exceptions. I called back and the next customer service rep gave me an email to send photos to, telling me "they'll look at it and send you a response tomorrow." I don't know who "they" are and I've yet to receive a response. I don't know how long it takes to review these emails...
I've never had a problem with Intel before and I sincerely hope this is a one-off. I'm so incredibly shocked and disappointed. I hate thinking I was lucky that only my motherboard was damaged and it could have been a lot worse.
Najan, Sorry to hear you had such a disaster with your PC. I've never had anything like that happen to me, or have seen anything like this.
After looking at your pictures, particularly the second picture of the bottom of the CPU, I have a few comments.
The rectangular area at the center of the CPU, which only contains capacitors, is clearly damaged by heat or burning, several of the capacitors seem to have literally melted or have detached from their connection points as if the solder melted.
The electrical contact points on the CPU (known as the substrate land's) seem to have indentations on them, apparently from the contacts in the socket. While you can clearly see that the socket contacts have left marks nicely centered in the CPU substrate lands, I have never seen indentations like that on any CPU's that I have. Another thing that is strange is that there are two areas in the socket where there are no contact pins, which can be seen in Figures 3-2 and 3-3, and described in section 3.1 of this document:
http://download.intel.com/design/processor/designex/324644.pdf http://download.intel.com/design/processor/designex/324644.pdf
Given that, I don't understand why there are indentations on the CPU substrate lands in the areas that correspond with the areas on the socket that do not have contacts. The indentations on the CPU substrate lands can be seen on almost every land in the second picture.
After examining that second picture, and checking the document in the link above, IMO it seems there was a problem with the socket, or possibly excessive pressure on the CPU for some reason.
I think it states in the CPU warranty that the use of an after-market CPU cooler can void the CPU warranty. Is there anything in particular that is causing you to think the CPU is the problem, rather than the mother board?
I'm surprised that the retailer that sold you both the CPU & motherboard didn't replaced both of the (2) parts. Both parts are under manufacturer's warranty so there's really not much of a question of returning it. Customer's satisfaction is guaranteed or your money's back as long as you purchased it within a specific time frame clearly written in front or at the back of your receipt (usually 14 days for electronic stuff). You could have just walk straight to the customer service & return the products or have it replaced. Simple as that. You don't have to call Asus or Intel to have it replaced. That's the job of the retailer where you purchased the deffective part &/or parts.
Some retailers even provide (for a small) fee a replacement product if that product gets destroyed as a result of voltage problem or overclocking for the entire 3 years (past the manufacturer's warranty). I got my Core i7 2600K CPU with warranty protection ($29.99) that I've purchased at Micro Center.
Having the retailer test the parts to determine which part is defective is not really the wise thing to do. You have the option to return the product when it's still under the retailer's warranty. Next time go straight to the customer service & return the product. You don't have to justify yourself. Tell them that you're not satisfied of the parts that you purchased & you think it's deffective. You tell them you want to return them or have them replaced with a similar or if you opted, for different product &/or products.
I purchased lots of stuff over a decade & my experience tells me that it's not really that complicated returning stuff you don't like as long as it's within the seller's return policy. As long as you return it while it still can be returned then there's shouldn't be any problem.
