17514 Discussions
i7 930 Processor Temperature Question
Hey guys,
I am freaking out kind of. I bought my brothers computer off of him and here are the specs:
Intel Core i7 CPU - 930 @ 2.8GHz (8 CPUs)
4098mb Ram
1gb Ati Radeon hd 5870
Idk how to find what motherboard
BIOS Date 2/24/10 ver 8.00.15
I ran speedfan and the temperatures were this idle with 68 processes running :
Am I okay? or what I was playing a game maximum and its reached like 80C for each core but the CPU said around 70C.
DSilv11
Valued Contributor III
You are in the gray zone....
It is a bit hot, but not so hot that you can say that there is an issue for certain.
I like to see the CPU <70 under max load.
I would check your chassis fans (since the screen shot is not showing any)
Try running a test with the case open and see if things are cooler. If so , you need a fan to get the heat out of the chassis
Check the CPU heatsink instillation. Make sure all 4 pins are snapped into the mother board
Make sure nothing like cables is blocking the air flow.
Last resort might be a after market heatsink (parsec has a number of postings listing some good ones.)
I would try to get the temp down if you can since if your hitting the thermal max, the CPU will throttle and you loose performance.
