16865 Discussions
i7-3610qm vt-x enabled in BIOS but not available in VirtualBox
KKole1
Recently I started using virtual machines on this cpu. More recently (two weeks ago) I tried to run a 64bit VM and VirtualBox throw me an error for not supporting 64bit VMs (as it came out after I checked). As far as I know this cpu supports vt-x which is responsible for the 64bit virtualisation. The computer is Asus K55VD. A couple days after those errors my bios died. I changed the chip and now the computer is working but still no 64 bit VMs for me. The problem is that I'm not sure if I had this VT-x or not and when/how it disappeared. I just wanted to know if is it possible for the cpu to lose this particular instruction and because of that the bios to die or from the beginning I haven't had vt-x and for now I've just being lucky working with 32bit VMs
Ronny_G_Intel
Hi Kolyo,
Intel® Virtualization Technology (VT-x) is supported by this processors, see the following URL: http://ark.intel.com/products/64899/Intel-Core-i7-3610QM-Processor-6M-Cache-up-to-3_30-GHz ARK | Intel® Core™ i7-3610QM Processor (6M Cache, up to 3.30 GHz)
What error message are you getting from VirtualBox?
KKole1
Sorry for the late answer but anyway. The message from VB is something like: "VT-x/AMD-V hardware acceleration is not supported on your system. Your 64-bit VM wont be able to detect 54-bit CPU and wouldn't be able to boot. (I'm translating on the go, because my VB is not in English.)"
