Good day.
I would like to know the average power consumption value (in range would be fine as well) when the i7-3615QE processor is undergoing the Intel Thermal Analysis Tool (TAT).
The reason is to know the suitable power value range to be set in the thermal simulation analysis for identifying the heat sink effectiveness.
It is understood that the datasheet do provide the Thermal Design Power (TDP) value, but whenever this value is used in the simulation, the simulated temperature will exceed the maximum junction temperature (105 degree Celsius). As such, would like to know the logical power consumption value range when undergoing the TAT process. Thanks.
链接已复制
2 回复数
Hello jiahaw823
Thank you for joining this Community.
I understand that you are looking to get the average power consumption values when the Intel® Core™ i7-3615QE Processor is undergoing the Intel Thermal Analysis Tool (TAT).
In this case, since this is an embedded processor, you will need to contact their special forum community, which is in charge of this type of inquiries.
You can submit your ticket here:
https://embedded.communities.intel.com/select-display-name!input.jspa https://embedded.communities.intel.com/select-display-name!input.jspa
I hope this helps,
Diego S.
