16774 Обсуждение
i7 4770k failing? or more tests needed?
thuan21
Начинающий
2 060Просмотр.
fresh build sometimes failing Intel Processor Diagnostic Tool. Took everything out including graphics card and extra stick of ram and did cross testing. All that's in the case now = CPU, CPU cooler, 1 stick of Crucial Ballistix Tactical, SSD, PSU. All settings stock, no OC.
-BSOD - Memory_Controller error
-Intel Processor Diagnostic Tool, sometimes passes, other times it fails at Integrated Memory Controller Test, Memory Verification Test 1 Fail. (Max temp 65 Celsius)
-Memtest86+ for 9 passes(8 hours or so), no errors. (Max temp 48 Celsius)
-Windows(8) Memory Diagnostic Tool, no errors returned either.
-Prime95 FPU/Small FFT test: 1 core fails immediately (Max temp 74 Celsius)
-Prime95 Blend test: Fails immediately: Hardware Failure, Fatal Error: Memory Controller error. (Max temp 77 Celsius)
-DPC Latency- steady yellow, ~1000 Micro Second latency
-Intel Burn Test, Fails Standard test within 5 passes
Idle temp: 27 Celsius, Regular On load temp: 44 Celsius, Max temp during stress test 77 Celsius
Full build:
-i7 4770k @ 3.50GHz (stock settings)
-GA-Z87x-UD4 F7 bios
-Crucial Ballistix Tactical DDR3 1600 @ 1.50V, 8-8-8-24, 2x8GB, took out one 8GB module for testing purposes.
-Plextor 256M3 SSD, Firmware updated to the newest 1.07
-Corsair HX750 Gold plus PSU
-Windows 8.1
-Newest drivers installed
Any help would be appreciated, thanks!
Daci
0 баллов
1 Ответить
Allan_J_Intel1
Сотрудник
1 193Просмотр.
Hi dacimvrl,
If the processor is still under warranty please get in touch with our Warranty Department so they can help you to replace the unit: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Allan
Ответить
