16969 Discussions
i7 4770k running hot.
PCone
The i7 4770k I purchased is running a bit hot for me when at 100% usage.
When compressing videos in Virtualdub I notice the temps are around 74-76C on some of the cores.
These are around the same temps I get with Prime95.
I've tried Intel Burn Test and Aida64 for testing my CPU and those bumped it to 92C.
Keep in mind I am using one of the best CPU heatsink air coolers on the market (Noctua NH-D14).
This is with only 1.2v on the CPU. If I used the heatsink included in the box it would easily run 15-20C hotter.
What I am asking is if it's possible to RMA my CPU for this reason?
When looking up the info on the box it says my Warranty lasts until August 2017.
Silvia_L_Intel1
Hello RyviusRan, I'm sorry to hear that you are having issues with this system.
I have seen this behavior before and sometimes it is cause by the memory.
Some recommendation I could give are the following:
The following link will provide more information about the http://www.intel.com/support/processors/sb/CS-033342.htm Processors — Processor operation temperature FAQ
If the issue persisted please contact our warranty team or submit a web ticket to request an RMA for this processor if it is still under warranty https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us
