16771 Discusiones
i7 4770s play a video game with no overclocking
Empleados
2.694 Vistas
i have an i74770s 3.1ghz,i need to play a video game with minimum requirements of i5-750 2.67 ghz and a recomended i7 3770 3.4ghz
.can i run it without enter in overclocking(i don´t wanna use overclocking)?
please let me know
0 kudos
7 Respuestas
Empleados
1.821 Vistas
Hello dumboix,
Could you please let me know the name of the game? That way I will be able to double check the requirements and help you.
Amy.
Empleados
1.821 Vistas
Thanks for your reply amy,
The game in question is mortal kombat xl.
Can you please tell me something about these 2 also?
The witcher3
The rise of the tomb raider anniversary edition
Kind regards
Empleados
1.821 Vistas
I cross checked the requirements for the games you mentioned, and it looks like the processor should handle all of them; however, I noticed that there is a requirement for the graphics card, you might need to take that into consideration.
I have found some helpful links where you talk to each game community;
http://forums.cdprojektred.com/forum/en/the-witcher-series The Witcher Series - CD PROJEKT RED Forums
http://community.wbgames.com/t5/MORTAL-KOMBAT-X/ct-p/MKX MORTAL KOMBAT X - WB Games Community
http://www.tombraiderforums.com/ www.tombraiderforums.com - Powered by vBulletin
From my end, you will find more optimized games for your graphics here; https://gameplay.intel.com/HardwareGames/75124/Intel%C2%AE%20Core%E2%84%A2%20i7-4770S%20Processor%20(8M%20Cache,%20up%20to%203.90%20GHz) Hardware Games.
Amy.
Empleados
1.821 Vistas
One last question is about this one called metal gear solid 5 the phantom pain.
Please let me know
Kind regards
Empleados
1.821 Vistas
Same history with this game, the required processor for this game is 4th Generation Intel® Core Processor which in this case your processor fits that requirement. The recommended operating system are Windows 7 or 8, and remember the graphics card. Check here for the official requirements http://www.konami.jp/mgs5/gz/en/products/steam.php5 METAL GEAR SOLID V: GROUND ZEROES - Official Site.
Let me know if there is something else I can help you with.
Amy.
Empleados
1.821 Vistas
Yes,My processor is from the 4th generation,but it s 4770s@3.1ghz of standard speed and the required processor for this game is 4790@3.6hz of standard speed.what are the consequences of playing this game with my processor instead of the required one ?
kind regards
Amy_C_Intel
Empleados
1.821 Vistas
The worst case scenario is the that the game will not work or perform as expected. As mentioned before the processor should be able to handle it.
Amy.
Responder
