16773 Discussions
i7 6700k only can boot windows or usb with one core
psusi
i have problem with my pc, when i turn on my pc stuck on loading splash screen, and i try to change on bios setting only 1 core, and with this i can boot into windows but can't with all core
https://www.youtube.com/watch?v=LpV7YqGwVdA
AlHill
Update your bios, reset to default settings. (do not disable any cores)
Then, boot to windows.
Doc
psusi
i have latest bios from asus website.
AlHill
Then, you have to consider that one or more of the following is bad:
  • Motherboard
  • Processor
  • Power Supply
  • Memory
  • Disk
Doc
psusi
i leave all disk drive, ram 1 stick and boot only to usb with windows 10 instaler, and bootloop or stuck in logo windows loading screen. only can boot with 1 core to usb with windows 10 instaler or drive with windows 10.
AlHill
Make your install USB from here. https://www.microsoft.com/en-us/software-download/windows10
If it does not work, you need to look at those Items I listeded in my response above.
Do not disable any cores.
Try different memory.
Try a different power supply.
Try a different drive
If you can boot to the bios, and if you have updated your bios (with all cores enabled), then there is something else going on.
Make certain the board bios is set to defaults.
Make sure UEFI boot is enabled.
If you have added a graphics card, remove it and use the onboard graphics.
This is what you need to do to troubleshoot and diagnose the problem. It requires work, and patience.
If you want to blame it on the processor, fine. But, we do not know that the processor is the problem (yet).
Where did you get the processor? Is it used, or new?
Try using only one stick of memory and then using the other stick(s) individually.
Doc
AlHill
Also, what is the complete model number of your motherboard?
Doc
psusi
i can boot to bios and i can update the bios, uefi enable and legacy but same thing. and cannot boot into usb with windows instaler .
i7 6700k i buy new.
asus z170 deluxe
ram corsair psu corsair hx750i
AlHill
Ok, but I had a lot more question there that you did not answer or do.
First, make a new USB install stick from the Microsoft link.
Doc
