16774 Обсуждение
i7 7700 temp spikes and revvving fan up and down (Should I RMA?)
Сотрудник
2 500Просмотр.
Can someone tell me if my processor and CPU fan are good or if I need to RMA it? The fans rev up and down when opening apps like IE, etc. Attached is my IPDT, the stress test results at 15 minutes, 25 minutes, and 5 minutes after the stress test. I'd like to know before I ship this one back. The fan thing is annoying, but if it isn't hurting anything I guess I can get used to it.
0 баллов
2 Ответы
Сотрудник
1 315Просмотр.
Hello patricki,
I would like to gather more information regarding your system configuration this in order to find the most accurate way to address the behavior you mentioned, please respond the following;
Amy.
Сотрудник
1 315Просмотр.
I worked with an intel tech through email and talked to someone at Micro center and it appears the behavior is normal in the 7700 and 7700K. you may close this thread.
Ответить
