16761 Discussions
i7-7700K I broke 2 x capacitor (delidding) it still works WHY ? ? ? + IMAGE
LFish1
So , I just delidded my I7-7700K and when i take photos a open cpu i dropped my phone on him ( IMAGE at the down )
And unfortunately i destroyed 2 x capasitor ,they dropped out of the cpu
I was thinking he (cpu) died completely but it works
And even works OC 5.0 ghz
Question , can someone who knows what these capacitors are ,what are they doing ?
Please explain
How its possible its work?
Thank you very much ! ! !
LukasStone.
LukasStone: Thank you very much for contacting the Intel® Processors communities and for providing the picture. We will do our best to provide the information you are looking for.
In regard to your question, it is hard to tell exactly the reason why the processor is still working, we had some similar cases where the processor does not work at all, sometimes it works fine, and some other times it works, but depending on the functionality that those pins had, it might not work properly or certain features will just not work.
In reference to the specific functionality of those capacitors, that information is confidential, and if by any chance is available, we will need for you to sign an NDA (Non-Disclosure Agreement). If you are interested in doing that, please let me know.
Any further questions, please let me know.
Alberto R
LFish1
Dear Alberto R
Thank you very much for your answer to my question
Im still very stressed out that something is wrong in my CPU
Because i noticed in some games that i play i have strange drop fps , graphic jumps from 20 fps to 100 fps
Before this same game in the old my pc i did not have this problem
LukasStone
LukasStone: Thank you very much for letting us know that information. I sent you a private message, please check your inbox.
Alberto R
LukasStone: I just received an update in this matter, Due to this physical damage we do not recommend using that CPU anymore. The capacitors are meant to withhold electrical current that the internal circuitry needs for specific logic gates out of the billions in the die itself, and the continued usage of this CPU compromises the entire system stability.
Alberto R
Valmiri
hi i was replacing a new processor i7 2600 an one of capacitors ore resistors i dont know is missing and i cont know if it is a capacitor ore resistor,if you can help
me whith what it is ant value i will rtu to
find and solder a nother one,were can i sent uou a picture of it
