16765 Discussions
i7 920 temp at load to high???
I have an i7 920, with a coolermaster n212+ and AS5 thermal paste. The CPU idles around 33+- 3 degrees celsius. However when load testing it the temps hit 80 degrees celsius, Is this to high and if so what can I do to fix it. The bios is set at normal settings no overclocking. Also can someone tell me if a stock voltage of 1.25v is normal. This is what it shows under load. The only thing i Can think of is to redo the thermal past application...I am really frustrated with this...
Under load those temps are fine. nothing to worry about
