17146 Discussions
i7 930/Ram configuration
I was looking at my RAM upgrade information, it says:
  • Triple channel memory architecture
  • Six 240-pin DDR3 DIMM sockets
  • Supports PC3-8500 (DDR3-1066) DIMM types
  • If this is the case, I was wondering if the following ram would work my motherboard/cpu configuration:
  • SAMSUNG 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model MV-3V4G4D/US
  • Also, would you all think adding the i7990xX would be a good idea?
Adolfo_S_Intel2
Please provide the RAM part number, it is usually a long number so we can find the specifications of that RAM.
Also provide the processor model that you are currently using so we can check voltage requirements.
I'm using an:
• Intel(R) Core(TM) i7-930 quad-core [2.8GHz, 1MB L2 + 8MB shared L3 cache]
About the ram in particular:
Learn more about the SAMSUNG MV-3V4G4D/USModelBrandSAMSUNGModelMV-3V4G4D/USType240-Pin DDR3 SDRAMTech SpecCapacity8GB (2 x 4GB)SpeedDDR3 1333 (PC3 10600)Cas Latency9Timing9-9-9-24Voltage1.5VECCNoBuffered/RegisteredUnbufferedMulti-channel KitDual Channel KitFeaturesVery Low Profile
100% Genuine Samsung Memory
RoHS Compliant
When I look up the information for upgrading my ram, with regards to my particular
Motherboard-- it says to use a 240 pin DDR3, PC3. 8500 (DDR3 1066). This Samsung
Ram is a PC3 10600, DDR3 1333, 240 pin.. So I'm curious if it will in fact work.
