i9 13900HX cores
ErikRomb
I have a laptop with a i9 13900hx cpu.
According to the specifications there should be 24 cores: 8 P-cores and 16 E-cores.
But when I look in CPU-Z or in the Intel Processor identification utility, only 15 E-cores are reported.
What am I missing? Or is there something wrong with my CPU?
Kind regards
Erik
JedG_Intel
Hello ErikRomb,
I understand that you would like to view all the cores available on your processor. One potential reason for the cores not being displayed could be related to Windows settings. The number of cores may have been modified or altered within the operating system. To resolve this issue, please follow the steps outlined below.
1. Press on the Windows key + R at the same time on your keyboard to open the Run window.
2. Type msconfig in the Run window, and click OK.
3. This will open the System Configuration window.
4. Choose Boot tab.
5. Click Advanced options.
6. Uncheck Number of processors, under BOOT Advanced Options.
7. Click Apply, then OK.
8. Restart your system.
For reference: Why Does my System Have Fewer or Missing Cores?
You may also check the number of available cores using the Windows Task Manager, you may refer to this link for more information: How to Check Number of Cores and Threads in My Processor?
Should you have other questions or concerns, please let me know.
Jed G.
JedG_Intel
Hello ErikRomb,
4. Choose Boot tab.
Jed G.
JedG_Intel
Hello ErikRomb,
I wanted to check if you had the chance to review the information I shared. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
ErikRomb
Hello Jed
Thank you for your message. Your solution indeed fixed the issue, I was not aware of that setting in msconfig.
Kind regards
Erik
JedG_Intel
Hi ErikRomb,
I'm glad to hear that the issue is fixed after following the recommendation. Since the issue is resolved, I will now close this inquiry.  If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
